Need help setting my new lr upper control arms.
Discussion in 'Suspension' started by 01kingtaco, Feb 26, 2013.
  1. Feb 26, 2013 at 12:10 AM
    01kingtaco
    01kingtaco [OP] Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    Iv read through all of bj mooses threads bout his control arm setting and count less others and I'm still confused. I know If I don't want the tires to rub on the cab to set the the lca to move it forward but then what do I set the uca to then. Factored in that at zero on the new uca is actually equivalent to +2.0 degrees. So where should I set the came to get no rubbing. The ome lift I got is Havana raise the front about a whole 3 inches. Any help would be great.
  2. Feb 26, 2013 at 3:06 PM
    01kingtaco
    Kodiak
    Maui hawaii
