Need help! Switched trailer lights to led now they won't work.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Theredbaron7, Apr 7, 2018.
  1. Apr 7, 2018 at 9:38 AM
    Theredbaron7
    Theredbaron7 [OP] Well-Known Member
    2017 Tacoma Sport
    Like the title says. Converted my boat lights to led and now they won't work on my truck. Its a 2017 sport with tow package. It worked before with the old bulb style. It also works on my other vehicle and a friend's truck. I've searched everywhere and can't find any solutions to this problem. I want to go boating HELP!!!!
  2. Apr 7, 2018 at 9:42 AM
    9TRDTCO
    9TRDTCO Well-Known Member
  3. Apr 7, 2018 at 12:42 PM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    LED's are polarity sensitive.
    Key-Rei likes this.
  4. Apr 7, 2018 at 12:48 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Most likely you have at least one led wired backwards. Power will only flow one direction with LEDs if one gate is backwards it creates a dam and stops the flow of current, test your polarity before installing.
  5. Apr 7, 2018 at 2:11 PM
    Theredbaron7
    2017 Tacoma Sport
    Yes I have tried switching the polarity. It did not work.
  6. Apr 7, 2018 at 4:59 PM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    I’m pretty sure there is a fuse for the trailer lights in the truck. Have you checked that?
  7. Apr 7, 2018 at 5:52 PM
    Theredbaron7
    2017 Tacoma Sport
    Replaced the harness and lights. Works now.
    TSAVO likes this.
