Need Help to Figure out Electric start problem?
Discussion in 'All Terrain Vehicles' started by timofthehill, Jul 2, 2011.
  1. Jul 2, 2011 at 11:44 AM
    timofthehill
    timofthehill [OP] Timmy
    Timmy
    Caledon Ontario
    06 Prerunner SR5 TRD Debadged
    7" Suspension Lift, 3" Body Lift, 33's on 17's, K&N Intake, Magnaflow Cat-Back Exhaust
    Hi everyone,
    I have a 1997 Yamaha Kodiak 400 also known as a YFM400. Last night the electric start stopped working. I have checked the voltage on the battery which is sitting around 12.6 volts. I checked to see how much it drops when you hit the start button and it drops to 12.4 I think or down to 6 volts. I can't remember the number. when you hit the start button you hear a click and the neutral light goes dim. What can I check to see where my problem might be? Is there a relay somewhere that involves the starting of the machine? what should my voltage be on this bike? Let me know what you guys think.
    Thanks
    Tim
  2. Jul 2, 2011 at 12:12 PM
    timofthehill
    Timmy
    Caledon Ontario
    more info to add. The battery sits at 12.6 and when you hit the button drops to 5 something and stays there til you turn off the key, then it jumps back up to 12.6. when you have the quad running it charges around 13.8 to 14.2. When you start playing with the throttle, the battery drops down to 8.28 til you let off and it will jump back up to its 13.8- 14.2. The neutral light flickers while all this is going on.
  3. Jul 2, 2011 at 12:20 PM
    timofthehill
    Timmy
    Caledon Ontario
    Sorry guys stupid me didnt think. I did a couple more test and found out that my battery is toast.
