Need help today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Aug 6, 2015.
  1. Aug 6, 2015 at 1:06 PM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
  2. Aug 6, 2015 at 2:50 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I used a 7" u-bolt to secure the bracket during my first install. I had a bag failure that Air lift warrantied, so the bags and brackets are on my work bench now. I welded a 6" (flexible, bendable) rod the bolt you are referring to, and will see if it will allow me to feed it through the frame and into the hole. I am going to do this in morning, so will let you know, I think it will work.
  3. Aug 6, 2015 at 3:05 PM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    I'm anxious to hear the result. I don't have a torch, but maybe I can use a u-bolt.
    Thanks
  4. Aug 6, 2015 at 3:14 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    There is a gap on either side of the crossmember. You have to get a wrench through it and get the bolt in. I used a piece of masking tape to tape the bolt to the wrench to keep it on.
  5. Aug 6, 2015 at 3:19 PM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Another thing to try, thanks
  6. Aug 7, 2015 at 8:17 AM
    jbrnigan
    Midwest
    VA - sent you a PM with photo, let me know if you didn't get it.
  7. Aug 7, 2015 at 8:53 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Thanks so much guys. The masking tape and end wrench worked for me. What a pita this was. Air Lift sent the wrong bottom brackets and left out the kit to connect the air lines, plus I had to enlarge the side holes of the top bracket. Air Lift was quick to correct the issues.
    Thanks again!!
  8. Oct 8, 2015 at 9:19 AM
    gkhamrhead
    gkhamrhead Active Member
    Greg
    Fayetteville, NC
    Gringo
    How are the Air Lift bags working for you?
  9. Oct 8, 2015 at 9:30 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    I didn't like them. Every time I needed to level a load, I had to have a compressor. My air tank wouldn't air them, neither would my foot pump. The on board air compressor was not in the budget. I returned them and went with helper springs. So far, so good.
