!!!Need Help!!! Total Chaos Removal
Discussion in 'Suspension' started by Jedi7Taco, Feb 25, 2012.
  1. Feb 25, 2012 at 12:21 PM
    Jedi7Taco
    Jedi7Taco [OP] Well-Known Member
    Josh
    San Diego
    07 4x4 DC LB sport Indigo Ink
    Stuff...
    Need help, anybody ever remove total chaos UCA's, I am in the process right now, but can't seem to remove piece number 10. See pdf in link (page 3)
    http://www.chaosfab.com/pdf/96504.pdf
    It's wedged in pretty good.
    Any ideas
  2. Feb 25, 2012 at 12:32 PM
    Jedi7Taco
    Josh
    San Diego
    Stuff...
    Bump for ideas
  3. Feb 25, 2012 at 4:10 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Take a large sledge and have someone hold it on the backside of the spindle (behind the hole) then smack the other side across from the hammer with a smaller sledge. Give it some good wacks and it will probably pop out.
    Or maybe you could rent a ball joint press and find a way to rig it to work. Hard to say without seeing it in person. Or maybe carefully with a brass punch or a regular punch and tap it out from underneath? or maybe a small slide hammer with a j hook on the end?
