Need Help Toyota Mechanics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Therazman, May 31, 2013.
  1. May 31, 2013 at 10:57 AM
    Therazman
    Therazman [OP] New Member
    2009 Ivan Stewart Tacoma
    2009 Toyota Tacoma 6 cylinder,
    I added a vacuum gauge, and I think I have it hooked up to the wrong vacuum line, I have it taped into the vacuum line right behind the air intake the gauge works but does not fluctuate. I had one hooked up to my 1970 Z-28 and the needle rocks back and forth when you hit the gas, it was tapped directly into the manifold.
    Is there another line that I can tap into or do I have to tap directly into the manifold? The gauge looks cool when it rocks back and forth.
    Thanks for the help[​IMG]
  2. Jun 1, 2013 at 5:21 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    You'll have to find a place to tap in after the throttle body. The throttle plate opening and closing varies the vacuum as it restricts (throttles as in old time word for choke) the amount of air to the engine
