Need help, truck suspension sways uncontrollably
Discussion in 'Suspension' started by Ragley10, May 15, 2019.
  1. May 15, 2019 at 3:23 PM
    Ragley10
    Ragley10 [OP] Active Member
    Gio
    00 v6 std 4x4 sr5
    Hi,
    When driving and I hit a bump, the truck swing left to right uncontrollably. It feels like I can lose control of the truck easily going 60+ mph. It’s tend to bounce to the right a lot when I hit a bump. Would this be the suspension? I’m wanting to replace the full suspension to see if this will eliminate the boat feeling of truck. Crazy part when I go over a speed bump it doesn’t bounce like the shocks are blown. What could it be?? This my first Tacoma it’s a 2000.
  2. May 15, 2019 at 3:25 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Stock or lifted?
  3. May 15, 2019 at 3:26 PM
    tcjacado
    tcjacado Well-Known Member
    Tie rods... inner and outer. Lower or upper ball joint.
  4. May 15, 2019 at 3:27 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    That’s why we cool jay
  5. May 15, 2019 at 3:28 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Lower control arm bushings.
    tcjacado and Ragley10[OP] like this.
  6. May 15, 2019 at 3:32 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I think you already answered yourself...
    For your own safety, it sounds like you may need to just take it to a shop.
    Likely parts that will need to be replaced, in a ranked list of what is most likely to be the problem.
    • Lower Ball Joints (LBJs)
    • Tie Rod Ends (TREs) - there are inner AND outer
    • Upper Ball Joints (UBJs)
    • Lower Control Arm bushings (LBJ bushings)
    • Steering rack bushings
    • Shocks
    • Upper Control Arm bushings (UCA bushings)
  7. May 15, 2019 at 3:34 PM
    Ragley10
    Gio
    00 v6 std 4x4 sr5
    It’s completely stock. Thanks for quick response guys! I’ll be checking be the tie rods and upper and lower ball joints. Polishing up my diamond part by part.
  8. May 15, 2019 at 3:37 PM
    JasonLee
    15 TRD OffRoad
    wilcam47 and Ragley10[OP] like this.
  9. May 15, 2019 at 3:42 PM
    tcjacado
    Huh?
  10. May 15, 2019 at 4:02 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    You knew the answer right away, posting at the same time :facepalm:
    Just go with it man :evil:
    tcjacado[QUOTED] likes this.
  11. May 15, 2019 at 4:07 PM
    Ragley10
    Gio
    00 v6 std 4x4 sr5
    Thanks gents! Y’all nailed it right on the money. I’ll be replacing it all with new parts. :spending:
    wilcam47 likes this.
