*Need Help w/ Factory Bluetooth!*
Discussion in 'Audio & Video' started by GEENYUSS, Aug 12, 2010.
  1. Aug 12, 2010 at 9:09 AM
    GEENYUSS
    GEENYUSS [OP] Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    5100’s Eibachs, SPC UCAs, 5125’s, General HD Leafs, 33x12.5x15
    I know how to use the bluetooth in my truck, but what i dont understand is:
    When I make a call it says "no name"?? Is there a way that i can program names in my trucks phonebook? Im using a ATT blackberry 8130. not sure if these radios allow transfering of your phones phonebook or not? but i tried transfering my phonebook to the truck via bluetooth but it wouldnt work?
  2. Aug 12, 2010 at 9:22 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    To my knowledge you can only set 6 speed dial numbers with your truck not transfer the phonebook.
  3. Aug 12, 2010 at 9:26 AM
    GEENYUSS
    Colfax, CA
    then why does it say "no name"? it seems like it has the ability to store names??
  4. Aug 12, 2010 at 10:43 AM
    JasoTaco
    You can name the pre-set shortcuts. It's pretty lame. I just hit the off hook button then "1" then off hook to call my #1 preset. using the speaking option isn't really much of a shortcut.
  5. Aug 12, 2010 at 2:32 PM
    limeyx
    limeyx Well-Known Member
    Nick
    Los Angeles, CA
    2010 Tacoma
    You can (sort of) transfer phonebooks (or add manually)
    What I did was:
    1) Go to Phonebook
    2) Go to add entry
    3) go to add by phone (i.e. from your phone)
    the BT will now warn you to prepare the phone to transfer.
    On my Droid, I select the contact and press Menu then Share then Bluetoth
    4) Say "Confirm"
    5) Hit send on the phone
    6) record a name in the car.
    Yes, I have to do it ONE BY ONE an yes it takes FORever
    and as far as I can see, the BT phonebook has a really small capacity, maybe 10-20 entries, which is really lame.
  6. Aug 12, 2010 at 5:21 PM
    TacoFred13
    TacoFred13 Where am I and what am I doing in this handbasket!
    Fred
    Klein, Texas
    Super White TRD Sport LB
  7. Aug 12, 2010 at 9:21 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    blackberry's do not support the transfer of phonebooks via bluetooth, i tried to do the same thing with my tour 9630, but after much research, i found out i just had to do it by speaking to the system
