Need help w/ Firestone Air bags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Taco, Apr 21, 2010.
  1. Apr 21, 2010 at 8:46 PM
    Black Taco
    Black Taco [OP] Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    My Tacoma was in need of some rear end help. I know this comes as a big surprise. I went with the Ready Lift 1" block in the rear which is great until the camper is hitched up. So I decide to go with the Firestone Ride Rite's because they sit on the axle. Come to find out that the blocks need to be removed for proper installation. Will the air bags give me the 1" lift at minimum pressure to achieve being level again? I really prefer these over the Air Lift system. No TSB= Out of warranty. Thanks.
  2. Apr 22, 2010 at 3:40 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You should get that lift no problem at min pressure. I set the pressure at 7 psi unloaded and experience at least an inch of lift.
  3. Apr 22, 2010 at 7:43 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    Thanks Fortech. I also got the wireless Air Lift compressor set-up. Can't wait to get them in.
