Need Help w/ " How to remove interior double cab floor carpet? "
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ill ay, Jun 18, 2022.
  1. Jun 18, 2022 at 11:18 AM
    ill ay
    ill ay [OP] I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    I'm looking to swap out the interior floor carpet from my double cab and I was looking for some d.i.y guide or video. I tried searching and I couldn't find any on YouTube of here. Can anyone share one and also let me know what to look out for when doing this? I will be on a time constraint to get it done and don't want to run into any mishaps. How long does this usually take as well? I've removed my center console, front and rear seats before so I'm familiar with that process.
    Thanks in advance.
  2. Jun 18, 2022 at 8:16 PM
    DaleRS
    DaleRS Well-Known Member
    Dale
    Cleveland, Ohio
    2015 Black DCSB SR5 w/ Snugtop
    Not sure of any tutorials out there but it's relatively simple. Since you have knowledge on removing front seats and console that's good considering that's the majority of what needs to be removed. Otherwise, the door sill plastic covers need to be removed as well as the kickplates on the driver and passenger foot wells. Those door sills hide a piece where the carpet latches onto the cab so that will need to be undone. Then the rear seats and underseat storage need to be removed. IIRC, some of the rear seat belt bolts need to be removed and in my case those were a b*tch to remove.
  3. Jun 19, 2022 at 5:42 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If you are replacing the carpet, you might as well go with the all weather flooring along with installing sound deadening tiles to the floor and back wall.
  4. Jun 19, 2022 at 2:11 PM
    ill ay
    The Valley
    Got it done! Took my time and made sure to not scratch or damage anything as the interior plastic is prone to it.
    Thanks to those who helped.
