Need help: Want to Sea Foam my Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Jul 31, 2010.
  1. Jul 31, 2010 at 12:38 PM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
  2. Jul 31, 2010 at 12:41 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
  3. Jul 31, 2010 at 12:47 PM
    DrRabbitFurHead
    Salem, VA
  4. Jul 31, 2010 at 1:19 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    :ohsnap:
    and
    :worthless:
  5. Jul 31, 2010 at 1:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    There is a vacuum line diagram right on the inside of your hood. Find the brake booster line, take it off, stick it in the seafoam real slow while adding some throttle. Then watch her smoke.
  6. Jul 31, 2010 at 1:27 PM
    DrRabbitFurHead
    Salem, VA
    My hood is so dirty from going off road that I'd have to wash it to find the sticker.:D Also, I'm learning a BUNCH about automotive DIY stuff (just changed my first O2 sensor on the wife's 2001 Sequoia last night and I've got the busted knuckles to prove it. If I knew which line was the brake booster, I would not have posted the question. :eek:
    Rep for the first pic posted!
  7. Jul 31, 2010 at 1:39 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Got a pic of the v6 off google and drew an arrow to the brake booster. There is a vacuum line from the intake manifold to the booster. Take it off at the booster.
  8. Jul 31, 2010 at 1:42 PM
    DrRabbitFurHead
    Salem, VA
    That's a 1st gen pic. I'll post the rep for effort but can't really see the line in the pic (even after blowing it up). Thanks... More rep for a 2nd gen!!!
  9. Jul 31, 2010 at 2:09 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    It's the large line going from your firewall to your engine head next to the brake fluid resivoir. Take it off and let it drink but no pedal. Pretty much in the same place as the 1st gen. Make sure you do 1/3 in gas tank and 1/3 in crank case (oil) then drive for 50mi. Let the brake booster suck up the last 1/3
  10. Jul 31, 2010 at 3:50 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Sorry man I wasn't paying attention. Thought it was a 1st gen post. I'm assuming you do have a v6 though?
  11. Jul 31, 2010 at 4:57 PM
    DrRabbitFurHead
    Salem, VA
    Yes, V6 4x4. Pics are under the camera icon on the left.
  12. Jul 31, 2010 at 6:01 PM
    ToucanV13
    Out of curiosity, have you tried youtube? That's how I researched mine
  13. Nov 12, 2011 at 5:56 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    I searched youtube before I sea foamed my taco today. Didn't really find anything showing which tube and what not so I figured I'd make a quick vid and post it up.
    Sea foamed my 95 integra the other day and the difference in the amount of smoke was huge! My truck didn't smoke much more than what was on the video.
    http://www.youtube.com/watch?v=T7WISFQ9PzI
  14. May 27, 2012 at 4:20 PM
    Kailey Jo
    Kailey Jo Well-Known Member
    Liam
    Ontario
    09 Access Cab TRD
  15. May 27, 2012 at 7:51 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Since no one else is specifically answering the OP's question:
  16. May 27, 2012 at 8:25 PM
    badger
    badger Well-Known Member
    07 SR5
    Just as an FYI, I use a squirt bottle to inject the seafoam into the vacuum line. I get a much more even and controlled flow that way.
  17. May 28, 2012 at 8:29 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    The vacuum will suck the sea foam right out of the can. You'll see.
  18. Dec 8, 2013 at 7:26 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Going to do this soon, hope the parents don't flip out.
  19. Dec 8, 2013 at 7:45 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I want to try this also!
  20. Dec 8, 2013 at 9:27 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Does it make a huge difference to poor a little of it into the vaccum hose versus all of it in the gas tank?
