"need help" wiring 3 hella compact 4000
Discussion in 'Lighting' started by 2000SIG, Dec 1, 2010.
  1. Dec 1, 2010 at 5:34 PM
    2000SIG
    2000SIG [OP] Well-Known Member
    I have 3 hella compact 4000 that I want to install on a defiant bar and I have a few question about wiring.The harness I got from hella is good for 2 lamps.Can I splice for my 3rd one?Will I need a bigger fuse?Anything else I should think about?
    thanks
    Marc
  2. Dec 1, 2010 at 5:43 PM
    SD2011Taco
    SD2011Taco Well-Known Member
    San Diego
    2011 SR5V6 4x4 Grey TRD Offroad Overland Setup
    3" Lift, Lights, CB, Yellow-Top, CBI Bed Rack, Tepui RTT, Shovel/Axe Mount, Maxtrax, ARB OBA, 33" KO2, Sliders
    The harness is junk. I ran all three of mine with 12 Gage to a single 30amp circuit.
  3. Dec 5, 2010 at 10:17 AM
    2000SIG
  4. Dec 5, 2010 at 10:39 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  5. Dec 5, 2010 at 10:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not familiar with the Hella harness but this is what I'd do. I'm sure you'd be fine splicing into the provided wiring though for one extra light. If you start blowing the in-line fuse then upgrade the wire size and use a larger amp fuse.
