Need Help Wiring HU
Discussion in 'Audio & Video' started by SMTRDSPORT, Feb 19, 2011.
  1. Feb 19, 2011 at 5:08 PM
    SMTRDSPORT
    SMTRDSPORT [OP] Member
    Eric
    Installing Pioneer AVH-4300DVD in 05 double cab w'JBL
    Anyone know off the top of their head what color wires I can splice into on the factory JBL harness by the head unit.. I have 3 wires left to do...
    Illumination Wire: I thought maybe the GREEN wire on the larger of the three harnesses but apparently its not correct.
    Mute Wire?
    Guessing I don't use the violet wire if I'm not using a back up camera.
    Thanks
  2. Feb 19, 2011 at 10:59 PM
    SMTRDSPORT
    Eric
    I think I have the wires correct, (minus I dunno where the "mute" wire attaches too) though when I start the truck the dash lights blink off/on and I hear a relay type clicking noise.. Anyone have any idea's? Originally the headunit turned on and seemed to be running fine for the first minute or so then all of a sudden it turned off and the dash lights started clicking off/on..
  3. Feb 20, 2011 at 8:20 AM
    cluck024
    cluck024 -cluck
    Robert
    Greenwood, Arkansas
    09 Prerunner TRD-OR DC Barcelona Red
    Blacked out badges, Anytime Fog Light Mod, Sockmonkey Decals and Third Brake Light Cover, Yellow fog lights, custom homelink install, Radflo 2.0 coilovers, LR UCA's, AAL, Moto Metal 957 matte black with Nitto Terra Grappler 285/70/17 shoes, more to come...
    Sounds like a short. Did you use t-taps for connections? If so, make sure they are tight.
  4. Feb 20, 2011 at 9:44 AM
    SMTRDSPORT
    Eric
    ya I used t taps (clearish crimp cones). I was gonna recheck all my wiring again.
    any idea where the "mute" wire is used for?
  5. Feb 20, 2011 at 9:47 AM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Used to be a mute wire was for connecting to a car phone (old school) so when it rings the stereo would "mute" while the phone was in use.
    Seems like that would be almost obsolete these days tho:confused:
  6. Feb 20, 2011 at 9:50 AM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Is the wire yellow w/ black??
  7. Feb 20, 2011 at 6:39 PM
    cluck024
    cluck024 -cluck
    Robert
    Greenwood, Arkansas
    I just installed the 4300 too. Dont have JBL but the mute wire was not used, and I cant tell that it had any effect.
  8. Feb 20, 2011 at 8:23 PM
    SMTRDSPORT
    Eric
    Yes there is a Yellow/Black Stripe wire which is the MUTE wire, I'm assuming that it'll only be used if you are going to use the optional bluetooth option. If I'm not, then the wire stays free of any connections.
    Stereo's up and running FINALLY... For future references for other members installing the PIONEER AVH-4200/4300DVD here is the wire diagraph. (*note: I have the JBL Package, so non JBL units MAY be different)
    AVH-4300DVD Colored Wire ----->>> JBL (Biggest of the 3) Harness Colored Wire
    Yellow (Constant 12v) --> Blue/Yellow
    Orange/White (Illumination) --> Green
    Red (Ignition Switch 12v) --> Gray
    Black (Ground) --> Brown
    Violet/White (Reverse Lead) --> Did not use since I wasn't using a backup camera
    Yellow/Black (Mute) --> Did not use since I wasn't using bluetooth
    Light Green (Parking Brake) --> 12v Relay (see http://www.tacomaworld.com/forum/audio-video/82657-pioneer-avh-p4200dvd-bypass.html)
    Blue/White (Remote) --> Use as your amp remote, also to the 12v relay - See above link if you're using the bypass method.
    8 speaker wires (White/Purple/Green/Gray) --> (http://www.tacomaworld.com/forum/au...tereo-system-scratch-2nd-gen.html#post2761110)
    Installing SWI-PS (steering wheel harness) to JBL Harness (Smaller of the 3 - This Harness only has three total wires on it)
    Red (Power) --> Connect to Red wire from AVH-4300 Harness (or Blue/White from OEM JBL Harness.
    Black (Ground) (Make into 2 wires) --> 1 end to White/Red on little 3-wire harness
    Black (Ground) (Make into 2 wires) --> Other end to ground (Brown on JBL largest Harness)
    White (splits as well) --> The resistor wired piece to White/Black
    White --> The NON resistor wired piece to Purple/White
    Hope all this is helpfull...
