Need help wiring rock/courtesy lights to cab switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 808stateofmind, Nov 13, 2023.
  1. Nov 14, 2023 at 4:02 PM
    caribe makaira
    Caribbean, Puerto Rico
    Violet (9), not Blue, since you are adding an additional switch.
    That would be personal preference and how and where you tie all the lights to the relay.
  2. Nov 14, 2023 at 10:23 PM
    808stateofmind
    808stateofmind [OP] Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    again, thank you for your help!
  3. Nov 14, 2023 at 10:25 PM
    808stateofmind
    Kona
    what excatly did you get, a wire harness of some sort?
  4. Nov 15, 2023 at 6:19 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Just shoot him a PM with what you're trying to accomplish, and he can provide a plug and play solution for you. Similiar to the item you posted, it plugs into the back of the cargo lamp switch, and the factory harness plugs into the other side of it; then if I remember correctly, theres a single ground wire to ground somewhere, a relay, and all you'll need to do is connect your single power lead (+) from your rock lights to the supplied and labeled relay wire (+). He essentially does all the hard work of all of the pinning/connectors/relay/etc thats described earlier in the thread and gives you a plug and play solution. It does exactly what you're describing (on/off with cargo lamp - door open/close/lock/unlock).
  5. Nov 15, 2023 at 8:31 AM
    808stateofmind
    Kona
    so to be clear, if I want the rock/puddle lights to function off of the cargo switch (come on with unlock, off with doors closed) but still be able to use an idependent switch to turn rock/puddle lights on if doors are closed than I need the switch to tap into the purple wire on the cargo switch harness instead of the blue if I wasnt using a switch?
    If i were to use a switch like a ch4x4 where do all the wires go to from the switch? like which one goes to the purple wire on the cargo harness, which one to the relay? do I tap into the green and/or the tan wires on the cargo switch to illuminate the new switch?
  6. Nov 15, 2023 at 9:03 AM
    caribe makaira
    Correct. You are completing the circuit (switching the ground side) of the added circuit.
    As I've stated before, you'll require a switch with independent illumination. The CH4x4 will not do.
    Green (+) Beige (-) switch illumination.
  7. Nov 15, 2023 at 9:14 AM
    808stateofmind
    Kona
    So if i use a 3 wire switch with no Illumination, one wire to the purple wire on the cargo harness, one wire to ground, and one wire to the relay? Sorry if i sound confused
  8. Nov 15, 2023 at 9:16 AM
    caribe makaira
    Correct, common one to relay coil.
  9. Nov 15, 2023 at 9:32 AM
    808stateofmind
    Kona
    Are you saying the same wire that goes to the purple wire will also go to the relay or the 3rd wire on the switch goes to the relay?
  10. Nov 15, 2023 at 9:40 AM
    caribe makaira
    :facepalm:
    On/Off/On switch.
    On (Door) Purple
    On White with Black (or your choice of color) to ground.
    Switch common (center) from relay coil pin 85.
    See post #18.:burp:
  11. Jul 28, 2024 at 10:34 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    OK. Late to the party here, but I have a question.
    I purchased the Universal DSIM kit because they don't make a Plug & Play version for my 2-Gen.
    This is the wiring diagram on how to install it. Note that the yellow wire is supposed to connect to the Rock Light Relay. The problem is, it does not say which pin on the Rock Light Relay.
    Any thoughts?
    @DSIM
