Need help wiring up an aftermarket VSC switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mario-Speed-Wagon, Jul 15, 2022.
  1. Jul 15, 2022 at 6:25 PM
    Mario-Speed-Wagon
    Mario-Speed-Wagon [OP] New Member
    2020 TRD Sport
    I wanted to move the Vsc switch to an open spot on the lower row of the driver side control panel with the larger sized switch hole. The new switch is a latch and I believe I need a momentary. I ordered a new switch from CH4x4 and soldered it in accordance to this thread:
    https://www.tacomaworld.com/threads/vsc-switch-wiring-diagram.696563/
    When I press the new button my VSC indicator on the instrument panel activates for a moment, and then deactivates itself. Is this because my wiring is wrong or because the switch needs to be momentary? Thanks!
  2. Jul 16, 2022 at 1:40 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The OEM button is momentary, but there are times where pressing & holding activate different options.
    You could check by turning your new button on then off again to see if VSC stays illuminated.
