Need help with 1st gen 5-lug lift
Discussion in '5 Lug' started by CUtigerfan, Nov 13, 2011.
  1. Nov 13, 2011 at 11:41 AM
    CUtigerfan
    CUtigerfan [OP] Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    For long story and background read lower paragraph.
    For you people that want bare bones info start under this:
    I've been looking around trying to find the Fabtech kits for the first gen 5-lugs and I'm not having any luck. I want the 3.5" coils and UCA and the 3" spindles so I'll have around 6" of lift and will probably run around a 32" tire. Does anybody know where I can find the UCA's and coils? It doesn't seem like anyones even selling them used anymore.
    At this point I'm thinking I'll have to go with the Total Chaos Taquito kit which is badass don't get me wrong but its gonna cost me alot more than I wanted to spend.
    Background and dilemma: I've had my 04 for about 3 years now and never did anything but slap some spacers in it when i was in high school. The whole college thing isn't working out for me right now so I'm taking some time off and working to figure out what I want to do before I waste more money half-assing my way through school.
    Right now I'm working a job that will only allow me to support myself and rent a house with a few friends. I am looking for an entry level position at a good company but nothings materializing right now. I do have a $5500 student loan from a year I spent at Clemson last year that I want to get out from under. I won't be spending any money on the truck until I better job and can make a big enough monthly payment on the student loan to pay it off in 2 years. Any extra money after that will be saved and spent on another vehicle or the truck I have now.
    With that being said I want a new vehicle or new to me. Its not practical for me to do so now I'm looking at lifting my truck again. Its a reliable truck and would probably be more practical lifted than anything I would buy. I thought I could piece together a 6" kit used but looks like most of these Fabtech kits are gone. For all of you thinking I'm a dumbass and don't have my priorities straight asking about lifting my truck you're exactly right but please keep reading if you can offer advice about lifting this truck (and life if you feel led to express your opinion).
    So now I'm looking at the Total Chaos Taquito kit. I would want to run a spindle along with it to get around 7" of lift total. Total Chaos says the kit gives 4" and the spindle would give me another 3". My problem is I don't know what I would do for the rear. I have a feeling slapping an AAL and a longer shackle along with some decent resi's wouldn't cut it. So I need advice on where to get the Fabtech coils and UCA's (I can find another brand spindle) or what to do about pursuing this Total Chaos kit.
    If you read all of this you deserve a medal or something but I appreciate any advice you guys have to offer.
  2. Nov 13, 2011 at 11:52 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Let me preface this by saying, I have little (more like no) experience with 5-lug trucks.
    With that being said, why do you want a 6" lift kit just to fit 32s? Is that necessary/the norm for 5-luggers?
    Fink
  3. Nov 13, 2011 at 12:05 PM
    CUtigerfan
    South Carolina
    04 Base
    No you could clear a 32" tire with less lift than that. I was just saying that was my plan. I'm not trying to clear the biggest tires I possibly can b/c I'm not looking to completely ruin my gas mileage.
    The more I think about this the more I think the Total Chaos kit might be overkill for what I want.
    I'm not sure if they would sell just the UCA but what if I got a pair of the UCA's from the Taquito kit? I could run longer coils (no clue how to go about figuring out where to get them or what I would need). Then I could run a 3" spindle and that would give me the 6" I want?? That sounds way too simple to be possible.
  4. Nov 13, 2011 at 12:16 PM
    Fink
    Orlando, FL
    The way I always approach these questions, is to first find out what you use your truck for.
    6" of lift is a lot, regardless of what you do.
    Anytime I lift a truck, I always go with the smallest lift possible to fit whatever tires I need. The biggest tire I would ever go on a DD is 285s (33s).
    With that being said, figure out what you're going to be using your truck for, even if it just looks, and go from there.
    Proper planning, even for something as simple as a lift and tires, can go a long way in padding your wallet.
    Fink
  5. Nov 13, 2011 at 12:28 PM
    CUtigerfan
    South Carolina
    04 Base
    I want to lift the truck and do it right. I put spacers in and found out the hard way they will limit downtravel. I bottom out going over speedbumps. I know the spacers have altered my suspension geometry and I'm trying to at least get my stock travel numbers back. I'm looking for ground clearance and looks honestly. I have no clue how the Total Chaos UCAs are engineered but from what I understand a UCA will bring the suspension back in spec and help with the preloading caused by spacers. I'm not sure if the Total Chaos UCAs are bolt on but it says on their site they require drilling out the spindle for the uniball. My thought was I might be able to make them work along with longer coils and shocks like the 3.5" kit Fabtech used to offer. I could add a spindle lift and get a full 6".
  6. Nov 13, 2011 at 3:37 PM
    TheAvgBo
    TheAvgBo Member
    James
    Lakeland, Fl
    11 tacoma 5 lug
    Fat bobs 2.75 front spacer, 17inch black Fuel Octanes, 265/70/17 Dyna Pro ATM RF10
    I had a set on my 1st gen 5 lug but cant remember who i got them from. Ill do some searching because i know someone sells them still.
  7. Nov 13, 2011 at 4:51 PM
    CUtigerfan
    South Carolina
    04 Base
    You mean new or used? I'm interested either way
  8. Nov 14, 2011 at 10:27 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Check this out... $78 more than the fabtech kit but you get coilovers
    http://www.doetsch-shocks.com/22.asp
    They also have one that's just lift coils that's cheaper than fabtech.
  9. Nov 15, 2011 at 6:41 AM
    TheAvgBo
    TheAvgBo Member
    James
    Lakeland, Fl
    11 tacoma 5 lug
    Those are the ucas i had on my 02. Thanks mowtaco i couldnt remember the name of them. They work great
  10. Nov 15, 2011 at 11:39 AM
    CUtigerfan
    South Carolina
    04 Base
    Awesome!! I knew Doetsch Tech made spindles but hadn't seen that kit before.
  11. Nov 15, 2011 at 1:49 PM
    MowTaco
    Kansas
    Only experience I have with them is shocks. They had great customer service and actually called me before shipping to verify the information I provided about my truck. Got the right shocks the first time, which is much more than I can say about the 3 times O'Reilly gave me the wrong ones.
  12. Nov 15, 2011 at 9:53 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    the tc uppers are 3.5 over. no way you can run that with stock lowers. cj siebler mich be selling his tc kit if you wanna talk to him
  13. Nov 15, 2011 at 10:00 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    and from what ive heard all those lift coils they sell give you a super shitty stiff ride
  14. Nov 16, 2011 at 9:11 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    You cant put coilovers in the first gen tacomas unless you get a new coil bucket like total chaos has for there taquito kit. I had a 96 tacoma and knew that suspension in and out. I had the fabtech kit and in ran like shit. If your going to be offroading id say get the taquito kit used somewhere you wont regret it. If your just going for lift and its going to be used for street just put a set of billies in it and a 3" lift spindle
  15. Nov 16, 2011 at 9:13 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    +1
  16. Nov 16, 2011 at 9:15 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    The other alternative is finding a used downey mid travel kit but that could be hard to come by. It replaces your upper and lowers gives you a custom bilstein shock with a threaded shock body and new coil to allow you to adjust ride height. I had it on my tacoma new it ran me 1200.
  17. Nov 16, 2011 at 9:21 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
  18. Nov 16, 2011 at 3:14 PM
    TheAvgBo
    TheAvgBo Member
    James
    Lakeland, Fl
    11 tacoma 5 lug
    X2
  19. Nov 16, 2011 at 3:35 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i read all of it!!:D
    hey if you want i can put your name in at work and if theres and opening might be able to get you it:notsure:
    pm me for mo info if your interested!
  20. Nov 16, 2011 at 8:20 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
