need help with 2002 tacoma front suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dave21ish, Dec 12, 2014.
  1. Dec 12, 2014 at 8:26 PM
    Dave21ish
    Dave21ish [OP] Member
    02 4 banging turd
    my 2002 tacoma suspension is pretty blown, i have a 3 inch lift and it bottoms out on speed bumps etc.
    most of the boots are leaky in the front suspension.
    basically want some help with what to get. i have bilstein in mind. no more than $200 budget.
    my brother said 2006 tacoma front shocks would fit 2002.
    is that true?
    let me know if anything should be made more specific. thanks
    rear suspension is fine, its lifted 3 inches.
  2. Dec 12, 2014 at 11:23 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Sounds like you might just need new shocks/struts for your truck. What brand lift do you have? When you say the boots are leaking, are you talking about the boots over the struts, or CV boots?
    You should be able to replace the struts in your coilovers for around $200, if you can do the installation yourself. Wheeler's has Bilstein 5100s for $173
    I have no idea if shocks from a 2006 (2nd gen) Tacoma would fit on your 2002 (1st gen), but I'm guessing you'll want to go with something that's made to fit with your truck and lift combination.
  3. Dec 12, 2014 at 11:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    shocks from a 2006 (2nd gen) Tacoma will not fit on your 2002 (1st gen)
  4. Dec 13, 2014 at 12:05 AM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    This.
    Go with bilstein or OME. I just put on bilstein 5100s with the stock coils on the 2nd setting and it rides great. You could probably use the coils you have on that lift and bilsteins and be happy.
    Our save a little more and get 5100s and eibach coils for the full 3in lift and a good ride
  5. Dec 14, 2014 at 3:04 PM
    Dave21ish
    02 4 banging turd
    its a spacer lift.. is that not going to work with the bill stein 5100?
    i bought the truck this way
    also what coils are worth getting? can i get a link?
    DOES ANYONE HAVE COUPONS FOR WHEELERS OFF ROAD??
  6. Dec 14, 2014 at 3:17 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    i got that, from what I've learned mixing and matching different lifts doesn't work very well.
    Read here:
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    And here:
    http://www.tacomaworld.com/forum/suspension/142677-suspension-lift-info-includes-pics.html
    Personally i would throw away the spacer lift and get a suspension lift but that costs some $$
  7. Dec 14, 2014 at 3:23 PM
    Dave21ish
    02 4 banging turd
    someone said the eibach coils would pretty much get the bilstein up to 3 inches?
  8. Dec 14, 2014 at 3:24 PM
    Dave21ish
    02 4 banging turd
    what eibach coils? where can i find them
  9. Dec 14, 2014 at 6:02 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
  10. Dec 16, 2014 at 7:58 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    On the cheap the 99 4runner coils and bilstiens. I got the coils from rock auto 40 sum bucks. You want the 16 inch rim option ones. 600lb.
