Need help with 2013 Hazard Switch/Clock Assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whiting1977, Sep 8, 2022.
  1. Sep 8, 2022 at 9:55 AM
    whiting1977
    whiting1977 [OP] Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    The Android head unit I purchased comes with a bezel trim frame that is made for a 2013 Tacoma. I have a 2014 and so the Hazard Switch/Clock Assembly does not fit properly. I need help from someone with a 2013 Tacoma.
    Can you tell me if yours uses a plastic bracket to connect the switch into the back of the trim frame? My 2014 does and that is the part that does not fit properly in the new bezel trim frame. The screw holes and the tabs do not line up.
    Would anyone have any pictures they can share if this assembly?
  2. Sep 8, 2022 at 10:07 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I have a 2013 and it did not fit either. I used some hot glue so that it could be reversible if need be :)
  3. Sep 8, 2022 at 1:17 PM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    How did you deal with the missing bottom two tabs that hold the trim bezel secure in the dash cutout?
  4. Sep 8, 2022 at 2:41 PM
    jpereira2
    Massachusetts
    Ahh. I used screws to mount it in so I don't think I utilized those
  5. Sep 8, 2022 at 3:27 PM
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    Okay thanks for the info.
