Need help with 3rd gen touch screen factory radio.
Discussion in 'Audio & Video' started by rins71mc, Aug 4, 2022.
  1. Aug 4, 2022 at 2:36 PM
    rins71mc
    rins71mc [OP] Active Member
    Blue Thunder 2017 TRD Sport
    K&N cold air intake
    Hi,
    My new to me 3rd gen Taco's touch screen radio started acting up today. When I crank my truck the radio starts beep like I'm touching buttons which I'm not and the screen starts changing like I'm pushing buttons. When this happens I can't control anything on it. Is there a quick fix or software update anyone nows about? Thanks
    Rinnie
  2. Aug 4, 2022 at 2:40 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Spill or scratch it, need a good cleaning ?
  3. Aug 4, 2022 at 2:48 PM
    rins71mc
    K&N cold air intake
    No sir, I even wiped the screen off in case I had too many fingerprints on it. Didn't matter.
  4. Aug 4, 2022 at 3:48 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    Either an update through a dealer or the more complex the headunit, the faster they crap out it seems. I’ll explain…
    -worldwide chip shortage has led to inferior product shipped out. You have 1 of 3 issues, or a mix.
    1 - bad U/X chip in the headunit that, under heat cycles, fails.
    2 - bad pin solders on the chip. You could, theoretically, tear the headunit down to boards and ribbon cables, de-solder then re-solder every connection, and rebuild it.
    3 - failed thermal paste on the amp chip, causing electrical gremlins to commence.
    If it’s under the 3-year warranty, try to get it replaced. Just remember, same chip shortage means a delay in replacement part. If it’s out of warranty, hit up www.Crutchfield.com , it’s time to upgrade anyways.
  5. Aug 7, 2022 at 6:25 PM
    rins71mc
    K&N cold air intake
    It seems to have fixed itself today. It's been raining alot so maybe the humidity had something to do with it. Fingers crossed
  6. Aug 8, 2022 at 5:51 AM
    ZMan2k2
    Richard
    ‘Berta
    :fingerscrossed: Is it cooler as well? Might be the pin solder problem.:annoyed:
