Need help with 6" lift measurements
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacoswb, Oct 6, 2010.
  1. Oct 6, 2010 at 4:40 PM
    07tacoswb
    07tacoswb [OP] Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    I have a Procomp 6" lift with the MX6 coilovers. I need to know what the measurement from wheel center to inner fender is. Currently i'm measuring 27 1/2 from wheel center to fender. My front cv shafts look a little like they did when I had my 3" lift on it. I got the coilovers from Procomp and just installed them since the instructions said they were set to height at the factory. I just wanted to check the height and adjust if necessary. Thanks for all the info. I did search but all info found was for a 3" lift.
  2. Oct 6, 2010 at 4:44 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    28" for me
  3. Oct 6, 2010 at 4:47 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Got any pics?
  4. Oct 6, 2010 at 5:44 PM
    07tacoswb
    Alan
    North Carolina
    Ok just took some pics.
    Thanks for the help.
    Driver's Side
    Passenger Side
    Also does the UCA angles look about right?
    Driver
    Passenger
  5. Oct 6, 2010 at 9:24 PM
    PLC721
    Patrick
    Chandler, Az
    looks the same as mine dude
  6. Oct 7, 2010 at 4:23 AM
    07tacoswb
    Alan
    North Carolina
    Cool that's good to know. Hey one more for ya, does your steering wheel seem to have a little wobble (right and left play) in it with your setup? I really didn't notice it with the 3" lift that I had with my Allpro UCA's. Just wondering if I need to get the LR UCA's so I can add some more caster. The alignment tech that aligned my truck could only get 2 degrees of caster with out messing the camber up. I think that from Toku's post 2.5 to 2.8 is what I need for 33's. I didn't know if having 35's if you notice it wobbling a little. Thanks for the help.
  7. Oct 7, 2010 at 8:57 AM
    PLC721
    Patrick
    Chandler, Az
    just a little bit yeah, but it's no biggie i got used to it lol
  8. Oct 7, 2010 at 10:39 AM
    07tacoswb
    Alan
    North Carolina
    Also after looking at the pictures that I took this morning the rear is a little lower than the front. So I did some measuring and the blocks that I have from the Procomp kit are 2.5" tall so I'm thinking of getting some 3" tall blocks so the front and the rear will be leveled better. I'm looking at getting some new leaf springs from Alcan for a 6" lift in the future but for now a fast fix would be that.
