Need Help with a Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benllua2, Oct 4, 2015.
  1. Oct 4, 2015 at 10:21 PM
    Benllua2
    Benllua2 [OP] New Member
    1998 toyota tacoma
    Hi All. I have a '98 basic Toyota Tacoma with 232,000. Been very lucky, a couple sensors changed and a new clutch. Recently my truck will buck a couple times( the radio starts popping) and die. The engine light comes on. I may get it started again but by the second time, its dead and doesn't turn over. We have a good family mechanic but he's stumped. Nothing showed up on the computer but a cam sensor which he replaced, but the truck still does the same thing. About three weeks ago I found myself in at least 12 in of water. The truck hesitated but I could drive through it. It didn't seem to have any effect. My current problem started about two weeks later. Our mechanic said I should go to a place that specializes in auto electrical. Any
    help I would appreciate. I'm not able to buy even a used car at this point.
  2. Oct 4, 2015 at 10:32 PM
    Fallguy6666
    Fallguy6666 Well-Known Member
    Check the ground from the firewall to the engine.make sure all grounds are good and clean.
  3. Oct 5, 2015 at 7:52 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The alternator on our trucks, especially the 5-lugs, are mounted low and therefore vulnerable to water. Thats what I would check out first. 12 inches is not very deep though, unless you didn't slow down enough.
  4. Oct 5, 2015 at 8:04 AM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    Welcome, Benllua2. I'd get that truck to a qualified mechanic pretty quick. Sometimes those electrical problems, if it is an electrical problem, can cause a fire resulting in a total loss of the truck. Had one do that but was able to get fire extinguished fast. Been using the same truck on ranch five years later now. Good luck.
  5. Oct 5, 2015 at 8:28 AM
    Benllua2
    1998 toyota tacoma
    thanks All. will check these things out!
  6. Oct 5, 2015 at 8:36 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    My bet is on poor grounds. A cam sensor would never cause a no-crank condition. No-start for sure, but not a no-crank. Next time the truck no-cranks, create your own grounds by running a jumper cable from the negative battery post to the engine block and body and see what you get. If it cranks, you've found the culprit.
  7. Oct 5, 2015 at 10:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    if you truly are worried about bad grounds, you can always add some extra grounds to your negative battery cable. all you're really doing is adding black (preferred) battery cables.
    not sure about your 98, but my 2000 has a cable going directly from the battery negative to the chassis about 8 inches away. you can put a bulkier negative cable there, and split form that body bolt to other locations via more wires if you want so long as they don't come in contact with any positive cables. . see what happens.
