NEED HELP WITH ADUSTING OEM RUNNING BOARDS!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Muskwa, Aug 19, 2012.
  1. Aug 19, 2012 at 2:36 PM
    Muskwa
    Muskwa [OP] I don't roll on Saturday
    Carl
    In a van down by the river
    08 DC SB SR5 TRD OFF ROAD
    Guys,
    I just installed the right side OEM running board on my '08 Double Cab.
    As you can see in the pictures, the front part is tight against the cab (behind the front right wheel).
    It seems when I tighten the bolts on that bracket (that bolts to the cab underneath) it sucks the running board up tight to the cab.
    Any suggestions?
  2. Aug 19, 2012 at 2:43 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Is the correct attach bracket in the correct position? Are the bolt holes slotted/elongated to provide some adjustment? Can you use an extra washer (or two) and longer bolt?
    I had to adjust my step tubes that came with my truck because they weren't installed correctly. A little Dremel work and minor modification and now they're how I want them.
    Good luck!
  3. Aug 19, 2012 at 4:57 PM
    nfowler
    nfowler Member
    Mid-coast Maine
    Tacoma SR5 4x4
    Stock
    Wow. I'd check the part number to make sure you have the right set. I just put the OEM running boards on my 2012 DCSB, and they fit perfectly. In particular, they are a bit longer than what I see in your pictures. Mine come all the way forward to the seam with the front fender flair.
    N. Fowler
  4. Aug 19, 2012 at 5:54 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    Left side???
  5. Aug 19, 2012 at 5:57 PM
    Larry
    Larry CARL
    CARL
    lets see pics from under
  6. Aug 19, 2012 at 6:01 PM
    Larry
    Larry CARL
    CARL
    make sure you have the correct bracket in the front position
    the front bracket on most boards/bars/tubes ia a little different that the mid & rear due to the stock hole location is slightly different forward
  7. Aug 19, 2012 at 7:43 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    I think that board is on the wrong side :confused:
  8. Aug 19, 2012 at 10:09 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Use a couple washers for shims.
  9. Aug 20, 2012 at 1:44 PM
    nfowler
    nfowler Member
    Mid-coast Maine
    Tacoma SR5 4x4
    Stock
    This is right. Unless you took the brackets off the running boards (mine came from Toyota with them all attached), you really can't install them on the wrong sides; the holes won't line up.
    The part number for my 2012 DCSB running boards is:pT212-35055. In addition, the instructions that come with them has a graphic that clearly identifies the right side running board from the left.
    N. Fowler
  10. Aug 20, 2012 at 2:32 PM
    Muskwa
    Carl
    Well guys,
    I used 4 - 1/4" - washers and it brought that corner down enough so now it's level.
    I just can't understand why the driver's side just bolted up correctly but the passenger side gave me problems.
    I guess that's just the way it wants to fit?
  11. Aug 20, 2012 at 2:43 PM
    Larry
    Larry CARL
    CARL
    something sounds wrong. you shouldn't have to use 4 washers to shim an OEM part.
    I'd check the brackets. does the front bracket use both holes under the cab?
  12. Aug 20, 2012 at 2:51 PM
    Muskwa
    Carl
    yup, the front bracket uses both of the holes under the cab, the holes in the bracket are round.
    where as, the middle bracket and the end brackets have a slotted hole for the top bolt and then round holes for the bottom bolt.
  13. Aug 20, 2012 at 2:54 PM
    Larry
    Larry CARL
    CARL
    thanks for the clarification
    sorry you had to have trouble with it. shouldn't have to...especially with OEM parts.
    what year is your truck?
  14. Aug 20, 2012 at 2:59 PM
    Muskwa
    Carl
    2008 DCSB
  15. Aug 20, 2012 at 3:02 PM
    Larry
    Larry CARL
    CARL
    shouldn't have been an issue.
    was the front bracket different than the mid & rear?
    and lets see pic from under and the finished product.
  16. Aug 20, 2012 at 3:06 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Nope. Something is wrong. Either on the truck or on the part. I have running boards and can cross reference any pictures you have by taking a peak at the truck.
  17. Aug 20, 2012 at 3:20 PM
    Muskwa
    Carl
    here are the pics
  18. Aug 20, 2012 at 3:24 PM
    Muskwa
    Carl
  19. Aug 20, 2012 at 3:31 PM
    Nixinus
    Oregon
    2010 4x4
    Ok. I will take a look at the truck when I get out of work.
  20. Aug 20, 2012 at 3:31 PM
    Larry
    Larry CARL
    CARL
    doesn't make sense
    has the truck ever had damage to the passanger side? near the mounting position?
    have you tried swapping the front bracket from the drivers side?
