NEED HELP WITH ANYTIME BACK UP INSTALL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yamota1617, Jun 26, 2020.
  1. Jun 26, 2020 at 1:15 PM
    Yamota1617
    Yamota1617 [OP] Well-Known Member
    sean
    17 Tacoma sr5
    Ok so need help!!
    I did my install and got everything working but camera ring light would always stay on, I know its because i installed the power wire from the camera to my blue seas fuse block which is hooked up to the battery.
    So then i took the power wire and i tapped it to the red wire coming from the switch thinking it would only come on when I turn on the switch.
    After that the switch stopped illuminating, it use to stay on all the time, well when the car was on
    Here is how I have my connections:
    The black and grey wire from the switch AND the black wire from the relay are all connected together and grounded to the bolt behind the radio.
    The red wire and the orange wire and the blue from the switch are connected to the red and orange wire to the braided line on the 28 pin connector that has the red and orange wire. The red and blue wire are connected together to the red wire on the braided line.
    The Green wire from the switch is connected to the green wire on the relay
    ever since I tried to tap the power wire from the camera to the red wire on the switch, the switch no longer gets power.
    I spoke to the people at anytime back up camera and he told me to connect the red wire from the camera to the green wire on the switch so the camera only comes on when i turn the switch, but i did my connections before he replied and now im not getting any power.
    Any ideas on what i should check or why my switch isnt getting any power?
  2. Jun 26, 2020 at 9:39 PM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    I ordered the same kit a few months back and same thing happened to me. I then hooked up the power wire from the camera to the switch and problem solved. This is a great mod that I use all the time.
  3. Jun 27, 2020 at 3:16 AM
    Yettee
    Yettee Well-Known Member
    Long Beach, CA
    2019 White Tacoma TRD OR 4x4
    OP here is a great instructional for front anytime https://youtu.be/DDiNGNWvPTM
    They do a really good job of laying out everything. I followed this mostly to a T and had no issues other than my own OCD for wiring and making things look clean and factory.
    Blackwolf likes this.
  4. Jun 27, 2020 at 5:19 AM
    TurboFire10
    TurboFire10 Well-Known Member
    Erik
    2018 TRD Pro
    ARE Revo, RCI rock sliders
    Throw that camera in the trash where it belongs and buy the $40 Natika on Amazon.
  5. Jun 27, 2020 at 5:21 AM
    Blackwolf
    Blackwolf Well-Known Member
    Paul
    Northern VA
    2018 Inferno DCSB TRD Off-Road
    I just installed the anytime backup camera kit and this video was really helpful.
    Camera power, and in your case the ring light power as well, should connect to the green wire from the relay. This gives power to the camera and light only when the relay is energized.
  6. Jun 27, 2020 at 5:37 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Why did you upload your pics as thumbnails?
