need help with Axel Blocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigdaddy99, Sep 6, 2011.
  1. Sep 6, 2011 at 5:27 AM
    bigdaddy99
    bigdaddy99 [OP] Well-Known Member
    Just recently got a 2000 tacoma . i know when i installed my blocks on my Silverado they had to go one way. The guy that did the intall on the yota has one way and the other different. My question is which side faces the rear? The fatter part of the skinner part?
  2. Sep 6, 2011 at 5:45 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Fatter part of the block should be at the back, it is tapered to allow for correcting the driveline angle.
  3. Sep 6, 2011 at 5:54 AM
    bigdaddy99
    thats what i thought what a retard he is lol how could you not notice that? i was trying to diagnose this horrific clunk when leaving from light when letting off the break nad decided to take a look at the blocks to make sure there were right and they were wrong... thanks for your help.
  4. Sep 6, 2011 at 6:09 AM
    bigdaddy99
    i was thinking of doin the u bolt trick in front of the axel i heard that helps? Im goign to start by flipping the one block then grease the slip yoke see where that gets me if not i will be trying this u-bolt trick heard it helps greatly. i would like to get rid of this stupid 2 piece driveshaft what a stupid design.
  5. Sep 6, 2011 at 7:08 AM
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Just another thought, if you still have a clunk after you correct the blocks, you may also have a bad U-joint, try to grab the driveshaft at each U-joint and yank it around to see if there is any play, there shouldn't be.
  6. Sep 6, 2011 at 7:26 AM
    bigdaddy99
    ya im going to replace them to pretty much goign to replace from the tranny mount back get everything fresh
