Need help with Billie 5125 installed measurements
Discussion in 'Suspension' started by dauange, Sep 15, 2010.
  1. Sep 15, 2010 at 4:05 AM
    dauange
    dauange [OP] Well-Known Member
    Central Ohio
    '01 PreRunner, Dbl Cab, 4 cyl
    Is there anyone out there that has Billie 5125's installed in an otherwise stock rear end of a 1st gen PreRunner? I'm having issues with levelness left to right and want to determine if the shocks are to blame. Mine are:
    Driver - 16" center of bolt to center of bolt
    Passenger - 18" center of bolt to center of bolt
    I know that the passenger is supposed to have 0.5" more travel but it seems like the difference that I'm measuring is too much.
    Thanks in advance.
  2. Sep 15, 2010 at 4:26 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    the shocks should just be dampening. the actual height and load capabilities come from the leafs.
  3. Sep 15, 2010 at 5:46 AM
    dauange
    Central Ohio
    So the entire load is carried by the leaf springs and none by the shocks?
  4. Sep 15, 2010 at 6:02 AM
    jhodge83
    SC
    right. you can completely remove the rear shocks and the truck is still drivable. drives like shit, but still drivable.
  5. Sep 15, 2010 at 6:05 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    The shocks dampen the rebound of the springs.
  6. Sep 15, 2010 at 6:10 AM
    jhodge83
    SC
    i know:D
  7. Sep 15, 2010 at 6:11 AM
    macgyver
    Brad
    Canton, GA
    Ah my bad...missed that post. oops...still finishing my coffee
  8. Sep 15, 2010 at 6:12 AM
    dauange
    Central Ohio
    So the shock is measuring 2" longer on the passenger side but uninstalled it is 1" longer. The passenger side of the truck is 1 1/8" high on the right. Based on input above, it would be the springs that are the issue. These are brand new factory springs.
    Is there any way to test the springs to see if this is the cause? I.E. I'm thinking remove them and put an equal load on the left springs and right springs and measure the compression distance?
  9. Sep 15, 2010 at 6:35 AM
    jhodge83
    SC
    were you told if they were made to be side specific? springs that is
  10. Sep 15, 2010 at 6:45 AM
    dauange
    Central Ohio
    These were replaced as part of a frame replacement that resulted in the truck having a significant droop on the left side. Dealership is being less than cooperative. I spent a couple hours with a tape measure and a flashlight last night. The best I can tell, the frame is straight and the body and bed are on the frame straight. That only leaves the suspension as a reason for the droop. Droop is much worse in rear than front but is still measureable in the front too.
    Don't know. Factory parts installed by "the frame dude". Any way to tell left from right?
  11. Sep 15, 2010 at 6:49 AM
    jhodge83
    SC
    i'd get the part numbers off them and search to see if the FSM says they are LH/RH specific
