need help with bilstiens and 285's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mtyoda, Aug 22, 2012.
  1. Aug 22, 2012 at 8:29 PM
    Mtyoda
    Mtyoda [OP] Member
    Brandon
    Montana
    07 Tacoma trd
    Bilstien 5100's in the front and 2" aal in the rear
    hey guys Im new on here and need help. Im sure the answers are here on tw but figured it would be faster to just ask. I have a 07 dclb and getting bilstien 5100's that I plan on setting at 2.5 with dick cepek dc-2 17x9 with 285-70-17 what am I going to need to trim? and how important is it that i get a diff drop? Thanks a ton and if anyone has pics that would be great.
  2. Aug 22, 2012 at 8:32 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    just do a search of 285-70-17. Bunch of threads on fitting 33" tires. But no need for a diff drop on the 2nd gen. Doesnt do anything helpful
  3. Aug 24, 2012 at 6:34 AM
    diesel30
    diesel30 Well-Known Member
    columbus ohio
    2011 dbl cab long bed trd sport 4x4 mag gray
    carbon fiber blacked out grill ddm tuning hid kit 35w/55w bi-xenon kit ddm tuning hid fog light kit 35w m/t classic lock blacks fierce attitudes 285/70/17 5100's installed on front 2.5" rear TSB done masterlock tailgate lock 35% front window tint scangaugeII duplicolor red caliper paint
    it really depends on what 285's you get. A/T's probably won't have much trimming to do. M/T's gonna trim a bunch. Make sure your wheels have 4.5" backspacing or you might hit your UCA's and the cab mount w/ MT's. I'm running 285/70/17's M/T w/ 5100's @ 2.5 and the tsb in rear.
  4. Aug 24, 2012 at 6:17 PM
    starwarsrosey
    starwarsrosey Well-Known Member
    Buffalo, NY
    17 Tacoma DCSB Limited
    Meso V4.0 Turn Signals Badges Blacked Out Blacked out foglight bezels
    what if u stay with stock rims. I posted the same ? with no replies yet. I have 5100's up front and tsb 4 pack in back. also have rear airbags. looking to run 285/75/16 at's on stock rims. will they fit?. also had 295/75/16 bfg at's in the past. would they fit. not really looking to start trimming stuff unless its just the plastic in the inside fromt fender wells. thanks.
  5. Aug 25, 2012 at 5:19 AM
    diesel30
    columbus ohio
    That's the only thing I had to trim was the fender liners in the front and rear of the front wheel wells. I didn't even touch any part of my bumper. They rub in one tiny spot when i'm at a certain degree turning but you turn past it and you're fine. With a/t''s, they wouldn't touch. You'll have zero issues on the rear. They only thing you'll have problems with is I believe a number of people have tried it with no success is that a 265 is the widest tire you can put on a stock rim. I haven't tried it personally so I can't answer 100% but i've seen a lot of people on here make that comment. Hope this helps.
  6. Aug 25, 2012 at 6:51 AM
    Mtyoda
    Mtyoda [OP] Member
    Brandon
    Montana
    07 Tacoma trd
    Thanks for the help guys, as it turned out the 285's ended up rubbing my cab mounts and I'm not about to trim those just for a tire so going to go ahead and put 265's on. But damn they looked good.
  7. Aug 25, 2012 at 7:04 AM
    diesel30
    columbus ohio
    with the right rim you won't have to touch the cab mount. I didn't and i've got 285/70/17's with no spacers.
  8. Aug 25, 2012 at 7:31 AM
    jeremy1ns
    jeremy1ns Gamecock Tacos
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    None yet, but its about to get rolling.
    So anything under 4.5 BS? That stuff really confuses me.
  9. Aug 25, 2012 at 8:37 AM
    starwarsrosey
    Buffalo, NY
    Deisel30 so what do u have the front billies set at? Srry but i am just starting to learn all of this.
  10. Aug 26, 2012 at 4:33 AM
    diesel30
    columbus ohio
    mine are set @ 2.5" and I'm running a 17" wheel with 4.5 backspacing. you could also set them @ 1.75 if you run 16" wheels as long as you use the 4.5 bs on the wheels.
  11. Aug 26, 2012 at 4:57 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    you will have to trim a bit, may need to take off the front mudflaps, but its totally worth it. love my 285's!
  12. Aug 26, 2012 at 11:26 AM
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I have 5100 at 2.5' in the front, no lift in the back at all. I had to do the cab mount chop and a lot of fender trimming to fit these, but I got it done...
    I have Light Racing UCA's, 285/70r17 Duratracs, and 17' Ballistic Jesters -12 offset and 4.5' backspacing just for reference.
