need help with blinkers
Discussion in '1st Gen. Tacomas (1995-2004)' started by santabarbarataco, Dec 2, 2012.
  1. Dec 2, 2012 at 10:40 AM
    santabarbarataco
    santabarbarataco [OP] Well-Known Member
    jordan
    santa barbara
    So both my front blinkers went out at the same time. I replace both bulbs to see if that fixes the problem. now the left one works fine, but the right sides doesnt. when I put the right one in and it just instantly blew the fuse. then I put a 15 amp fuse just to see if it would help, but now instead of blowing the fuse it just doesnt work at all. and the left ones continues to work fine. any suggestions as to what i should try next? i have been chasing all the wiring and it all looks alright.
    Thanks
  2. Dec 2, 2012 at 11:16 AM
    santabarbarataco
    jordan
    santa barbara
    Oh and if i turn on the hazard lights it blows that fuse as well, which is a 15 amp fuse
  3. Dec 2, 2012 at 11:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you replace the REAR blinker bulbs? Or ..check connections & sockets on the REAR (both sides)?
  4. Dec 2, 2012 at 12:04 PM
    santabarbarataco
    jordan
    santa barbara
    I haven't checked those, but they were all working fine then just both front went out. Ill check the rears too
