Need help with blown fuse or relay...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boost3, Jun 28, 2018.
  1. Jun 28, 2018 at 5:00 AM
    Boost3
    Boost3 [OP] Member
    2017 Tacoma Trd Off-Road dcsb
    While installing a Gentex 453 w/Homelink I accidentally touched the constant hot wire for the factory mirror (3 wires:constant, switched and ground). Now my dome light and power door locks only work if the ignition is on. Smart key, key fob and annoying beep when the door is open do not work. Nice not having the annoying beep but I need the other things. lol I have gone through the fuses with a multi-meter and everything checks out fine. Is there a relay that I should be looking for? Thanks in advance...
  2. Jun 28, 2018 at 5:41 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Any relay would be internal in the BCM. Sounds like you did some internal damage
  3. Jun 28, 2018 at 5:45 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    You do know there are 2 fuse panels ?
  4. Jun 28, 2018 at 5:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Did you check the ones under the hood as well as inside the truck?
  5. Jun 28, 2018 at 5:48 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Always disconect the battery when working on electrical.
    I would disconnect the battery, go back through the fuses and double check, then reconnect and hope for the best. If not, then you may have fried something.
  6. Jun 28, 2018 at 6:35 AM
    Boost3
    Boost3 [OP] Member
    Yes
  7. Jun 28, 2018 at 6:36 AM
    Boost3
    Boost3 [OP] Member
    Yep. Wondering if any of the relays have anything to do with it...
  8. Jun 28, 2018 at 6:37 AM
    Boost3
    Boost3 [OP] Member
    I will give it a shot! Any ideas what may have been fried? BCM?
  9. Jun 28, 2018 at 6:39 AM
    2016Tacoman
    J
    Kind of hard to blow out a relay.
    Might be stupid question but how did you check with meter ? In circuit or out ?
  10. Jun 28, 2018 at 6:56 AM
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    You’re probably going to have to take it to the dealer and have a computer replaced. When my shell was put on something got fried. Lost my lock unlock audible tone, interior lights no longer worked automatically, and lost the third brake light. Dealer replaced computer and reprogrammed at shell dealer cost.
    Boost3[OP] likes this.
