need help with brake problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black coma, Aug 27, 2013.
  1. Aug 27, 2013 at 10:09 PM
    black coma
    black coma [OP] Active Member
    edwin
    hesperia
    07 prerunner sr5
    None yet
    i am trying to install the maxtrac lift spindles and i had no problem with the passenger side but once i went to remove the stock flex brake line the upper connection seems to be stuck together. oncei thread it all the way out it gets stuck on the last tiny bit. it will continue to rotate but will not pull apart. i would greatly appreciate some advice. thanks guys
  2. Aug 28, 2013 at 1:12 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The line is over flared and catching on the threads. You are going to have to muscle it out. When I swapped my lines out for braided, I had the same problem and used a smaller open end wrench to pry it apart.
