Need help with brakes desparately!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaBanjo, Jan 8, 2025.
  1. Jan 8, 2025 at 12:14 PM
    ToyotaBanjo
    ToyotaBanjo [OP] Well-Known Member
    Outer banks
    2006 DC 4x4 Sport
    None
    2006- 4x4 Double Cab V6 275K miles 5100 Bilsteins, Deaver Rear springs
    I need help with my brakes!!!! I have been through 4 or 5 sets of rotors over the last few years..Started with replacing rotors...then pads...then calipers one at a time...6 months ago put the Adaptive One rotors on new (supposedly the upgraded nicer ones from Napa)....warping with 2 months....so we decided to replace everything again two months ago....
    Put brand new pads, brand new Adaptive One rotors, brand new adaptive one calipers, and replaced the rubber brake lines going to calipers...AND we drained all brake fluid and blew the lines out and replaced......2 months later steering wheel shaking when braking!!! And NO, I dont ride the brakes...I drive like an 80 year old and dont brake hard....90 percent of the driving is a 1 hour commute where I hardly hit the brakes on the whole trip....not pulling anything....
    What else is left to do!!??? Mechanic mentioned that we may have to replace the entire ABS module, that it could be defective and causing slight pressure and slight heating over time??
  2. Jan 8, 2025 at 12:22 PM
    Dillusion
    Dillusion Well-Known Member
    Kyle
    2018 TRD Sport
    Honestly I don't trust Napa any more.
    I've had Adaptive One pads a rotors on my 4Runner and Tundra and both started pulsing while braking within couple thousand miles. Even after bedding them when changing. I've been going with Bosch since I can Amazon them and its been better.
  3. Jan 8, 2025 at 12:37 PM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    But this is the 5th set...only the last two were Adaptive Ones....
  4. Jan 8, 2025 at 2:16 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Are the calipers pushing out the pads evenly?
  5. Jan 8, 2025 at 2:25 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    If you replaced your bearings it could be the hubs that are out of spec; meaning they have run out and your rotors follow them. So the rotors will run true for a short time and then they will wear unevenly causing a vibration. It can also be worn bearing causing the same thing.
    Chuy likes this.
  6. Jan 8, 2025 at 2:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you properly Bed The Brakes?
    From what you describe it isn't warped rotors. What you are getting is an uneven layer of brake material on the rotors that causes a pulsing feeling of the brake pedal and grabbing as you described. It seems you have wasted a bunch of money on brakes IMO.
    https://www.autozone.com/diy/brakes/bedding-brakes
    https://brakeperformance.com/beddin...rLQizd-l4GA3kiRf6yCtRoBeBXHykYU3b-gqJO9xurgwb
    You can bed in properly the brakes you already have installed and save yourself some money and time.
    Rob MacRuger and Clearwater Bill like this.
  7. Jan 8, 2025 at 4:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    How long did the original OE pads and rotors last?
  8. Jan 8, 2025 at 6:23 PM
    TacoTuesday1
    FL
    theres a thread. It documents the problem. It has a solution. It has many pages. It has been around a while. It is the first thing that comes up when you search. Try that.
  9. Jan 12, 2025 at 1:31 PM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Could not find anything in a thread about it. And yes I did look.
  10. Jan 12, 2025 at 2:47 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Torquing the wheels correctly?
    Superdave1.0 likes this.
  11. Feb 7, 2025 at 3:08 PM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Once again...can you please show me the thread!!!
  12. Feb 7, 2025 at 3:09 PM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Yes....torqued correctly....bearings all good...
  13. Feb 7, 2025 at 3:27 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I did my brakes Last July at 122,000 miles and used Advics rotors and Akabono pads. At 133,000 miles I can still see the machining marks on the rotors. All I did was use brake cleaner on the rotors and easy braking the first few applications. The plastic bags the rotors came in had a sticker on it that said, Certified High Carbon. I ordered from Rockauto.
  14. Feb 7, 2025 at 4:42 PM
    TacoMatic4x4
    TacoMatic4x4 Well-Known Member
    87' Suzuki Samurai, 98' Toyota Avalon, 2018 Cement TRD Offroad DCLB 4x4
    I've never had luck with aftermarket rotors. The price is nice, but they don't last as long and prematurely wear out or warp and cause vibrations. You end up spending more time and money changing them in and out. Spend a little extra on oem rotors for a better product. Less headache in my opinion.
    Lawfarin likes this.
  15. Feb 7, 2025 at 8:15 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I second this - at least measure the run out with dial calipers to rule this out. This is a standard item to check on cars with brake vibration issues.
  16. Feb 7, 2025 at 8:24 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Different vehicle but i had brake booster go bad and was giving constant pressure on brakes, to the point of overheating brakes. Changed booster and never had problem again
  17. Feb 8, 2025 at 4:00 PM
    esotaco
    esotaco Well-Known Member
    Ed
    Fairfax, VA
    '13 Silver 4.0L AT SR5 4X4
    I had my front brakes and rotors replaced by a local reputable shop about 1,000 miles ago but am now noticing some vibration when braking. The shop owner did not say anything about bedding. I drove off as I have after every other brake job. Can the bedding procedure be performed at this point?
  18. Feb 8, 2025 at 4:14 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You can bed them at any time. I do mine about once per year and mine always work great. Of course, I have the TRD Off Road so my brakes are pretty decent to begin with.
  19. Feb 8, 2025 at 5:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes.
  20. Feb 8, 2025 at 5:44 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Or bent spindle pulling on hubs
