Need help with brakes desparately!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaBanjo, Jan 8, 2025.
  1. Feb 8, 2025 at 6:14 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    x2 on the dial indicator and OEM rotors only. Been in the same situation with aftermarket rotors many times.
  2. Feb 14, 2025 at 4:48 AM
    ToyotaBanjo
    ToyotaBanjo [OP] Well-Known Member
    Outer banks
    2006 DC 4x4 Sport
    None
    On this truck does that mean I have to replace the entire ABS module? My understanding is that it is all built in?
  3. Feb 14, 2025 at 4:52 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Just a note also it is the left side (drivers) that is continually doing this. We dial calipered it and it is slightly warped already. (2 months after replacing EVERYTHING NEW….rotors calipers lines pads and bleeding system…torqued correctly….bedded. Runs perfectly and them two months in left caliper is warped. 5th set of calipers over last couple of years.
  4. Feb 14, 2025 at 9:24 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I don't believe your problem has anything to do with the ABS module. I like the idea of putting Toyota rotors and pads on. Be sure to completely clean any rust or anything off the rotor to hub surface. Be sure to use brake grease on the specific moving parts. Be sure to use new pad retention springs/clips. Break them in a little while then check the temperature of the rotors after a leisurely drive using an infrared thermometer.
    Sorry but I have to ask, you don't drive with one foot on the gas and one on the brake do you? You'd be surprised how common that is.
  5. Feb 14, 2025 at 9:46 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    I have done everything you said there. Except buy Toyota rotors.
    I hesitate to do that now knowing that there is an issue on the left side. Not normal to warp the same rotor every two or three months. And I have been using the upgraded heavy duty ones the last several times.
  6. Feb 14, 2025 at 9:47 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    And no I don’t drive with left foot on brake.
  7. Feb 14, 2025 at 9:48 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Or ride them. 90% of the mileage each day is actually road miles with the brakes rarely getting used.
  8. Feb 14, 2025 at 9:52 AM
    BTO
    California
    Compare the rotor temperature left vs right. That can confirm if you have a dragging brake
  9. Feb 14, 2025 at 9:54 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Have done that a few times and have seen it hotter sometimes. Figured that there is a slight drag causing it to eventually heat up. But after replacing everything several times can’t figure out what would cause the drag.
  10. Feb 14, 2025 at 9:55 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you don't have one, buy an inexpensive infrared pyrometer. I have one and use it more than one would expect.
    After driving, check temperatures of your rotors, hubs, etc., from one side to the other. If there's a dragging problem that is causing things to warp, heat is involved.
    I do this on my rear drums for a few weeks after replacing brakes to make sure I have things (the wheel cylinders) set evenly from one side to the other.
  11. Feb 14, 2025 at 10:02 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    My first car had a caliper that wouldn't retract full because of a bad flex hose (hardline to caliper), that would cause the caliper to bind and the rotor to overheat.
    Superdave1.0, po35042 and BTO like this.
  12. Feb 16, 2025 at 7:00 PM
    po35042
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    x2 on the flex hoses
    especially if they are from 2006. They degrade from the inside out, so they may look just fine on the outside.
    But what happens is they allow pressurized fluid from the master cyl in, but are too restricted to let the fluid flow out; results in dragging or binding caliper.
    winkel likes this.
  13. Feb 16, 2025 at 7:02 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    This is a very commonly overlooked issue. Have to torque the wheels correctly and evenly. It CAN warp the rotors if not.
  14. Feb 20, 2025 at 7:48 AM
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    They were replaced last time…
  15. Feb 20, 2025 at 7:49 AM
    #35
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    Torqued correctly with torque wrench each time
  16. Feb 20, 2025 at 7:50 AM
    #36
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    I did and it is the left side warping
  17. Feb 20, 2025 at 7:51 AM
    #37
    ToyotaBanjo
    Outer banks
    2006 DC 4x4 Sport
    None
    So after figuring that out again, we replaced everything rotors pads, calipers flex lines, and blew all of the fluid out of the system, and replaced it all! Two months later, left side, warped and shaking!
  18. Feb 20, 2025 at 8:08 AM
    #38
    bs63366
    bs63366 Well-Known Member
    San Angelo
    2014 Tacoma TRD Off Road DCSB
    ARE Z-series shell, ImMrYo mirror lift, always on fog-lights.
    Its sounding like you have replaced everything except your ABS unit in the line. If everything else is new except that, then thats the way I'm leaning. I think if your repair shop has the computer tool that can bleed the ABS module, they should be able to activate it and see if its properly letting the pressure off.
  19. Feb 20, 2025 at 5:50 PM
    #39
    hotwind
    hotwind Member
    capital region ny
    07 dcsb off road 6 sp speedway blue
    Has anyone checked out the rear brakes. Are the shoes adjust right. Are the shoes glazed and hardly working? Also wouldn't trust napa brakes get something better
