need help with breaks
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacomaowner, Nov 1, 2011.
  1. Nov 1, 2011 at 6:38 PM
    1998tacomaowner
    1998tacomaowner [OP] Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    so my calipers are leaking fluid and i wanna upgrade my brakes i was looking at LCE and there kit is almost 600$ just wondering is there somthing i can do to replace my calipers and upgrade the brakes that was cheaper
  2. Nov 1, 2011 at 6:49 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
  3. Nov 1, 2011 at 7:29 PM
    Wolfrunner
    Wolfrunner Well-Known Member
    Graham, WA
    '04 Tacoma Double Cab SR5
    Grey wire mod, 17" tundra wheels powder coated
    raybestos just came out with rotors for that year of pickup that are called the r-300's. install those with a set of ebc green pads and that would be all you need. plus make sure you have someone who knows what they are doing adjust your rear brakes. the rears are so often unadjusted that it seems like your pedal is worse than it could be.
  4. Nov 1, 2011 at 10:13 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    i was thinking about this the thread is helpful if you have a second gen is it the same as first?
    and im really worried if they will work with my wheels i only have around 1/2 in clearance or so as it is
    if all works out i will get tundra calipers and rotors and hawk pads possibly get steel braded lines as well
  5. Nov 1, 2011 at 10:25 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    yes, it will work on the 1st gen tacomas. i plan to do this myself in the near future. most guys that do it jump to 17s, but i think some have used 16s without issues. do more research on it and you can decide if its right for you. there are 2 versions of the tundra calipers that you can choose from.
  6. Nov 1, 2011 at 10:37 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    a bit more research yes and im going to add that i have 15s :confused::(:mad:
  7. Nov 1, 2011 at 11:04 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    unfortunately 15s are not going to work. early tundras came standard with 16s to clear these calipers.
  8. Nov 1, 2011 at 11:09 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    btw they are aftermarket rims dont know if it matters
    other ideas
  9. Nov 1, 2011 at 11:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ^^that does actually. Because like Wheelers makes a 15'' rim that will fit on toyotas i think with calibers that need 16'' rims..i think..
  10. Nov 1, 2011 at 11:49 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    i dont understand
  11. Nov 2, 2011 at 12:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Nov 2, 2011 at 12:28 AM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    oh so those work?
    mine arent like that i took my tape out and measured my rim and what not the tundra calipers are 10.5 in it looks like it would be so close if not fit mabey take the tire off and look measure some more
  13. Nov 2, 2011 at 9:56 PM
    Wolfrunner
    Graham, WA
    I helped a buddy put in the tundra calipers and he says the brake pedal feels different since he did it, like the master isnt big enough for those larger calipers
  14. Nov 2, 2011 at 10:44 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm contemplating the same upgrade, but hadn't heard of any problems with it. Sub'd...:popcorn:
  15. Nov 2, 2011 at 11:20 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    well i have 15 inch rims so today i when to auto zone got the tundra caliper it dident fit i dident think it would just wanted to see so i returned it and got a stock tacoma caliper 55$ no upgrades:( but the problem is fixed
    any ideas for some upgrading?
  16. Nov 2, 2011 at 11:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not really. I think the wheelers rims are it for the calipers maybe. Other then than just some good pads and rotors.
  17. Nov 3, 2011 at 7:47 PM
    Wolfrunner
    Graham, WA
    feel like I was talking to a wall here...Upgraded rotors and pads. check it out, I posted that wayyyyy up towards the top.
  18. Nov 3, 2011 at 10:43 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    yes thats the only thing i can do but i had to replace my caliper and i hate putting stock replacement stuff on if i can upgrade it
  19. Nov 3, 2011 at 10:52 PM
    Wolfrunner
    Graham, WA
    the factory calipers that came on toyota tacoma's are awsome calipers. Four pistions. I hardley ever see a toyota come in with a fully locked up caliper at work. The best part about the upgrade is just having to buy pads and rotors. but like I said earlier....Adjust the crap out of the rear brakes. Im in tacoma WA and if you ever were up this way I would show you the best way I have found to adj the rears so you get the most out of them.
