Need help with code p1135
Discussion in '1st Gen. Tacomas (1995-2004)' started by Niz86, Apr 9, 2021.
  1. Feb 25, 2024 at 5:48 PM
    pyranha7
    pyranha7 New Member
    Keith
    2002 Tacoma ext cab 4x4 3.4
    It was the upstream sensor. Replaced with denso sensor and no more CEL. No rust on mine. Southern truck with only 100k.
  2. Jun 7, 2025 at 5:28 PM
    Tangerine
    Tangerine New Member
    2002 PreRunner
    After a week of trouble shooting a loose ground wire was my issue :bananadead:
  3. Jun 8, 2025 at 8:14 AM
    Glamisman
    Glamisman Well-Known Member
    You will never forget this for the rest of your life and when you work on your buddys truck that has a problem and you figure it out you will be the hero, unpaid, but a hero.
  4. Jun 26, 2025 at 1:43 PM
    Roadie_
    Roadie_ Active Member
    A bit late to this thread but I'm having the same issue. Do you know where exactly the ground wire is located on upper intake manifold? I've searched everywhere and can't seem to find it
  5. Jun 26, 2025 at 9:08 PM
    Glamisman
    On the 3.4 locate the DIAGNOSE plug on the D/S upper intake, look by it and you will see a bundle or brown wires with black tracer. Take the bundeled ring terminal connections off the stud and give each individual wire a little tug and bend right where they are crimped. Lots of times the wire is broken internally.
    Roadie_ likes this.
  6. Jun 27, 2025 at 6:32 AM
    Roadie_
    Thanks! I'll give it a try later. Really hoping this is my dilemma as the sensor in question is a brand new DENSO. Not sure what else the issue could be...
  7. Jun 27, 2025 at 7:50 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Check for an exhaust leak.
  8. Jun 27, 2025 at 8:04 AM
    Roadie_
    Funny you mention this! I do, in fact have a pretty big exhaust leak (muffler is filled with rust cracks on edges). It's a bit loud and you can definitely smell it. I have a new one ordered and will be installing it this upcoming week. Hopefully that remedies the code.
    t0p_d0g[QUOTED] likes this.
