need help with driveshft angle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Texastaco2010, Sep 19, 2019.
  1. Sep 19, 2019 at 4:09 PM
    Texastaco2010
    Texastaco2010 [OP] Well-Known Member
    2010 TRD Tacoma
    gonna lift my truck about .5 inch more, I have the arb El096R right now and have a carrier drop kit, so would I need to get shims if I lift it .5
  2. Sep 19, 2019 at 4:20 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did you mean 1/2” lift, what would be the point?
  3. Sep 19, 2019 at 4:23 PM
    Texastaco2010
    2010 TRD Tacoma
    yeah dude 1/2 inch more
  4. Sep 19, 2019 at 4:26 PM
    gotoman1969
    Well a 1/2” lift gets you nothing, from a performance standpoint, is why I asked. I would at 2” you’ll want shims to correct driveshaft angles and usually anything above that also the drop kit to help with the cv angles. If you only 1/2” none of those will be issues.
  5. Sep 19, 2019 at 4:28 PM
    gotoman1969
    Is there a particular size tire you’re looking at?
  6. Sep 19, 2019 at 4:29 PM
    Texastaco2010
    2010 TRD Tacoma
    my bad I have a 2wd non 4wd idk if thatll make a difference and the reason for it is to slighty get rid of the rear sag
  7. Sep 19, 2019 at 4:30 PM
    gotoman1969
    How much lift are you running in the front?
  8. Sep 19, 2019 at 4:31 PM
    gotoman1969
    2wd 5 lug , or 6 lug prerunner?
  9. Sep 19, 2019 at 4:31 PM
    Texastaco2010
    2010 TRD Tacoma
    tire size not at the moment maybe I the future I think 3 right now
  10. Sep 19, 2019 at 4:32 PM
    Texastaco2010
    2010 TRD Tacoma
    6lug
  11. Sep 19, 2019 at 4:41 PM
    gotoman1969
    If you went 3”front 2”rear, adding the 1/2” spacer in the rear . You should be ok.
