Need Help with Engine / Transmission Compatibility.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pearson, Apr 8, 2022.
  1. Apr 8, 2022 at 5:14 PM
    Pearson
    Pearson [OP] Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    Hey all, I really need and would appreciate help with some engine & transmission compatibility information. Many of you know that I have been restoring a 2012 2.7L Prerunner with 220K on it. Its running fine but I know that the law of physics will apply to me sooner or later.
    I have found a low milage 2018, 20K 2.7 engine and transmission at what I feel is a good price. But I don't have any idea of what is compatible or needed to make for a reliable change over. Is there reference for such an undertaking? I know that the transmission would be my 4 speed to whatever was offered in 2018.
    Can anyone help me understand what I would be taking on? Buying like this would allow me to take my time and make ready for the change over given that my engine is running fine. I really like my truck and with all I have renewed to date a fresh engine and tranny would pretty much make it a new ride.
    I really would appreciate any help you might off. No disrespect intended, please consider that I know and love the life expectancy of the 2.7.
    But I am not asking for opinions regarding whether or not I should consider the change out due to mileage etc. Simply would like to hear what is compatible and the procedure etc.
  2. Apr 8, 2022 at 5:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    2018 will be a dual VVT engine.
    You’ll need the harness and ECU.
    I would think the motor and trans mounts would work. But I will let the guys with more knowledge on the 2.7 advise you on that.
    Pearson[OP] likes this.
  3. Apr 8, 2022 at 5:19 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Pearson[OP] and TnShooter like this.
  4. Apr 9, 2022 at 7:38 AM
    Pearson
    Elliott
    Lexington Texas
    Just my luck, This 2018 I found is priced right 20,000 miles on it original. So taking this as gospel, and thanking you for taking the time to advise. The question is if I do go with a 12 through 15 with my truck being a four-speed would it be compatible with a five-speed transmission if I found the right candidate?
  5. Apr 9, 2022 at 8:10 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you talking about the 5 speed manual or automatic?
  6. Apr 9, 2022 at 3:52 PM
    Pearson
    Elliott
    Lexington Texas
    Automatic, I wouldn't mind a manual but I don't even dare ask what all would be involved with that changeover.
  7. Apr 9, 2022 at 3:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I don't think the 5 spd auto (A750) will even bolt up to the 2.7L, also the PCM and wiring is different and the 2.7L was never offered with the 5 spd auto so other than something custom there's no PCM available for that combination.
  8. Apr 9, 2022 at 4:03 PM
    Pearson
    Elliott
    Lexington Texas
    This is very helpful info, Thank you!
  9. Apr 12, 2022 at 10:33 AM
    AgentCovert
    AgentCovert Well-Known Member
    22 SR5 DCSB 2.7L
    Not sure if this will help or answer your questions but the 2TR-FE is currently offered with a 6 speed automatic transmission in the 3rd gen and at one time even offered with a 5 speed MT with 4x4 in the 3rd gen as well as in the 2nd gen truck too..you may have better luck using the current 6 speed automatic transmission thats used for both the 2.7L I4 and 3.5L V6..
