Need help with exhaust
Discussion in 'Performance and Tuning' started by mnudo200827, Jul 2, 2010.
  1. Jul 2, 2010 at 6:52 PM
    mnudo200827
    mnudo200827 [OP] Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    Ok guys, i have been researching exhaust for a while and now my brain hurts, but havnt quite found what i was looking for. I know i want a magnaflow muffler and want a deep rumble just like everybody else. So here are a few questions:
    1)What is the differences in terms of sound between the 5x8x14, 5x8x18, and 5x8x24?
    2)Is a dual out exhaust going to make it deeper and louder?
    3)Do tips make a difference, i have heard both ways so dont know what to believe, i heard that longer rolled tips are the best for loud and deep.
    4)Would a bigger diameter exhaust pipe for the part coming out of the muffler make it deeper and louder, oh and i havnt researched it, but what is the stock diameter on our exhaust?
    Sorry but i am tired of looking thru all these threads, just to many to go thru. Thanks in advance...Mike
  2. Jul 2, 2010 at 7:19 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    how loud do you want it?i've got the trd,its kinda deep and growls ,but quiet when cruising.
  3. Jul 2, 2010 at 8:02 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    5x8x14 sounds good!
  4. Jul 2, 2010 at 9:02 PM
    mnudo200827
    Michael
    Corona, CA
    I mean i want to hear it a bit when i am cruisong but not abnoxious, but i want it to come alive when i get on it.
  5. Jul 2, 2010 at 9:04 PM
    mnudo200827
    Michael
    Corona, CA
    Thats what i figured, it seems like the smaller the muffler, the louder it is, i just want to know what the 5x8x24 sounds like compared to it.
  6. Jul 2, 2010 at 9:05 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Dual chamber dumped over the rear axle. Would probably go with the 18".
  7. Jul 2, 2010 at 9:08 PM
    mnudo200827
    Michael
    Corona, CA
    do you mean dual out, wouldnt chamber be inside the muffler, i am going with a magnaflow and those are straight thru.
  8. Jul 2, 2010 at 9:15 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Missed the part where you said magnaflow.
  9. Jul 2, 2010 at 9:17 PM
    krumble
    krumble Well-Known Member
    Jon
    Santa Clarita, CA
    SOLD 08 prerunner trd offroad SOLD
    debadged, tinted windows, magnaflow exhaust, afe CAI, 285x75 Nitto Terra Graplers, Engage LT front and rear
    I'd recommend having it dumped after the axle or "turned down". It supposed to echo the sound off the ground. Just make sure it is after the axle because before will make it quite loud inside the cab.
  10. Jul 2, 2010 at 9:18 PM
    mnudo200827
    Michael
    Corona, CA
    Should i use a tip on the turn down or does it even make a difference.
  11. Jul 2, 2010 at 9:19 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Here is my dual chamber flowmaster dumped over the rear axle for reference. I think your's might be a little quieter and less raspy.
  12. Jul 2, 2010 at 9:22 PM
    mnudo200827
    Michael
    Corona, CA
    wow i like how deep it is, and if mine wont be as raspy, im guessing cause mine will be straight thru right, then that might be the perfect set up. Thanks for the vid!
  13. Jul 2, 2010 at 9:29 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    215,000 and counting
    I disagree, if it's dumped before or after the axle the sound is the same. I've had both on two
    different trucks and I couldn't hear a
    difference. I'm currently running a DynoMAX
    dumped before the axle (LT suspension in the future) and it sounds great. If you go this route the tip wouldn't matter
  14. Jul 2, 2010 at 9:30 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Turbo+3"+side exit=nuff said :)
  15. Jul 2, 2010 at 9:31 PM
    mnudo200827
    Michael
    Corona, CA
    I think he suggested after the axle so that it wont be so loud in the cab, but on the outside it probably sounds the same
  16. Jul 2, 2010 at 9:31 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    ya ya ya, you and your fancy turbo.
  17. Jul 2, 2010 at 9:32 PM
    mnudo200827
    Michael
    Corona, CA
    hahaha, your probably right but i dont need a turbo, but i like the suggestion:D
  18. Jul 2, 2010 at 9:37 PM
    Htnswches
    E
    Lost Angels
    Yeah, I meant in the cab, sounds the same
  19. Jul 2, 2010 at 9:59 PM
    mnudo200827
    Michael
    Corona, CA
    is yours single in single out? And how loud is it in the cab while under normal acceleration and cruising, do you have to raise your voice to talk over it?
  20. Jul 2, 2010 at 10:01 PM
    mnudo200827
    Michael
    Corona, CA
    would it be louder with dual turn downs or would that just be rediculously loud and should i go with bigger diametered tubing on the exit part?
