Need help with fog switch
Discussion in 'Lighting' started by Redgrom, Dec 30, 2011.
  1. Dec 30, 2011 at 5:21 PM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Hello, just installed my piaa's and have a question about using a Toyota switch. After posting here I picked up a switch from the dealership (00550-35976) it's the generic toggle switch vs the Tacoma push button. It has 3 posts but I have know idea which one is which. Anyone with experiance with switches want to chime in? Wiring is not my thing!
  2. Dec 30, 2011 at 5:24 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    there should be numbers on the switch, for each post
    edit: one would be from the relay, one for a ground, and the other for the light in the switch
  3. Dec 30, 2011 at 9:52 PM
    Redgrom
    Brent
    san clemente
    Thanks! Will check it in the morning.
  4. Dec 31, 2011 at 1:25 AM
    Redgrom
    Brent
    san clemente
    Wow that makes it easy! Thanks!!
    Last question, the indicated light is the top correct?
  5. Dec 31, 2011 at 5:59 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Does it fit into the knockout slot properly?
  6. Dec 31, 2011 at 9:55 PM
    Redgrom
    Brent
    san clemente
    Yep, fit right in. Need to get the correct connectors when the auto parts store opens but it looks pretty good.
    Thanks for the help again. Sure I'll be back when I finally pull the trigger on a led light bar
  7. Sep 8, 2012 at 1:11 AM
    Redgrom
    Brent
    san clemente
    Referenced for tomorrows project
