Need help with friends 1991 4Runner V6 engine issue
Discussion in 'General Tacoma Talk' started by dms90, Jul 22, 2025.
  1. Jul 22, 2025 at 11:48 AM
    dms90
    dms90 [OP] Well-Known Member
    Dirk
    2004 Tacoma Double Cab 4x4
    A friend of mine has a 91 4Runner V6 (with about 190K miles) that has a couple of issues that the mechanic working on it has not been able to solve.
    Before taking the car to the shop it was running rough (and surging) and smelled of gas. The check engine light would come on intermittently and my friend took it to a local (non-toyota shop) to get it looked at.
    The mechanic said he could see gas coming from one of the fuel injectors and replaced the leaking injector with a rebuilt one. The mechanic has been unable to get it to run right. Apparently, when the engine is cold, it runs smoothly, but starts running rough when it heats up. He has replaced the first rebuilt injector with a second rebuilt one and the issue still persists.
    My thought was that OEM injectors should have been used.
    Does anyone have any suggestions as to what might be causing this problem and possible solutions?
  2. Jul 23, 2025 at 5:06 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    when were the spark plugs, and coils last replaced?
    i'd also consider cleaning the MAF, and inspecting the emissions system-- sometimes the return circuit will stop working which can result in surging as well
  3. Jul 23, 2025 at 5:14 PM
    dms90
    Dirk
    I will check and see if he knows the last time the plugs and coils were changed. Cleaning the MAF is also a good idea.
    Thanks, I will pass on the info.
  4. Jul 23, 2025 at 5:18 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    It's a 3.slow V6.
    Surely they checked for a blown head gasket, right???
    koditten likes this.
  5. Jul 24, 2025 at 3:06 AM
    dms90
    Dirk
    I would have thought that they would but I will find out today.
  6. Aug 9, 2025 at 6:37 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had an old Mazda pickup that would do that. It was a bad thermostat.
  7. Aug 9, 2025 at 6:58 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    3.blows dont have a maf. The have a afm that use a flap to gauge airflow and aren’t serviceable.
    It’s probably the ECT.
    No one knows how to work on these motors anymore so good luck. I would never recommend anyone that isn’t comfortable with a wrench and a multimeter to own one as it will drive you crazy. Pre odbii efi troubleshooting is a real art that most techs don’t have
    these motors made me a lot of money back in the 90s, and again in the 2010s tearing them out and dropping in 3.4s.
