Need help with fuse box -
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cobra6, Jul 28, 2010.
  1. Jul 28, 2010 at 9:17 PM
    Cobra6
    Cobra6 [OP] Well-Known Member
    Beri
    Tennessee Valley
    '06 PreRunner SR5 TRD Sport
    I bought my '06 Taco wrecked - I am still trying to fix a few small things - (see pic)
    one is - the Fuse and relay box Lower cover has the bracket bent (see lower area of picture next to the fender)
    I have the upper cover, but it will not fit since the bracket is bent, it will not fit on the cover.
    Is this fix as simple as removing the fuse and relay box and straightening the bracket - or do I need to look for another lower cover?
    one other issue is the small box that should hang off the back of the lower cover (hanging loose in the pic) - can anyone tell me what this is or a part number so I can get one?
    Thanks in advance for any help.
  2. Jul 28, 2010 at 9:56 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Is that the original fuse box ? Looks like a TRD Off Road fuse box to me, I think that small box is for the e-locker. Lower box part number is : 82663‑04010, gonna cost you about $65. The two main fuses at the top left of the pic, what amps are those ?
  3. Jul 29, 2010 at 8:19 AM
    Cobra6
    Beri
    Tennessee Valley
    the two main fuses at the top - the blue one is 100A, the red/purple one is 140A
    All I know is that this box was in the truck when I got it (and when it was hit - obviously) - It was hit on this side - had to get a new fender and headlight.
    The truck is an '06 PreRunner SR5 TRD Sport Double Cab, but since it is 5 years old something could have been replaced before the accident.
    What is the difference between the Off Road Fuse box and others?
    I am just trying to get the fuses covered.
    Thanks
  4. Jul 29, 2010 at 8:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Jul 29, 2010 at 8:27 AM
    Cobra6
    Beri
    Tennessee Valley
  6. Jul 29, 2010 at 8:27 AM
    Asgard
    A 140 amp fuse would mean you have the tow package, 120 amp without. Does your truck have the factory hitch ? Later I'm gonna give you a link to a part diagram site that you will find helpful.
  7. Jul 29, 2010 at 8:31 AM
    Cobra6
    Beri
    Tennessee Valley
    Yes - I have the factory hitch - and the wiring harness that plugs into the back was in the glovebox.
    If I took the lower fuse cover off, would that side bracket bend back? At least I know now I would need another truck with a tow package if I bought something froma junkyard.
    Also, I can't find that small box part for the E-Locker -
    Thanks again
  8. Jul 29, 2010 at 8:58 AM
    Asgard
    You won't need the e-locker if you have a TRD Sport, to make sure take a look at your rear diff fill plug you should see a sticker that says "LSD Oil Only". The fuse box is three separate pieces with the bracket being a part of the lower case, you then have the piece with the fuses and relays (held in by little side clips in the lower case), then you have the cover. You just need to lift out the piece with the fuses and relays and then replace the lower case.
  9. Jul 29, 2010 at 8:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  10. Jul 29, 2010 at 1:13 PM
    Asgard
    ^^Sorry, my bad. I thought it was the relay for the e-locker.
  11. Jul 29, 2010 at 1:53 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
