Need help with hard start
Discussion in 'Technical Chat' started by 2ndchancetoyotas, May 18, 2013.
  1. May 18, 2013 at 12:59 PM
    2ndchancetoyotas
    2ndchancetoyotas [OP] Well-Known Member
    Greg
    AZ
    Rebuilt
    I bought two Tacomas, one with a damaged front end, the other a freshwater flood truck.
    Used body parts from the flood truck to finish off and make one good truck. It is fully driveable.
    Back to the flood truck. Simply put - I only get spark for about 3 or 4 rotations, then the spark stops even if you hold key and continue starting. I do get a couple of combustion pulses along with the spark, then nothing.
    I'm using the ECM from truck 1. Already established flood ECM is innoperable. No spark no matter what happens.
    Verified immoblizer system by removing transponder ring from column and hang truck 1 key in it while using flood key to start truck. Immobilizer system continued to flash. Reassembled and no immobilizer indicator.
    Things that have been addressed already:
    Tank drained physically and also at return line after rails. Fuel pump is working. Fresh fuel added.
    Oil drained and refilled
    Throttle body is opening and closing normally.
    Compression 'feel' good.
    Spark is present using light tester that connects between plug coil and plug, but only for a few rotations.
    I don't have a scanner to read the data. Unable to verify if I'm getting crank or cam signals, though I could check resistance per manual.
    Will ecm spark discontinue if it doesn't read crank or cam signals? I can pull these sensors off a third truck if necessary. Any other ideas?
  2. May 18, 2013 at 1:33 PM
    2ndchancetoyotas
    Greg
    AZ
    Rebuilt
    Found this in the manual:
    "When the transponder key ECU detects that the unlock
    warning switch is ON, the ECU provides current to the
    transponder key coil and produces a faint electric wave.
    A transponder chip in the key grip receives the wave.
    Upon receiving the wave, the transponder chip outputs a
    key ID code signal. The transponder key coil receives
    this signal, the transponder key amplifier amplifies it, and
    then the signal is transmitted to the transponder key
    ECU. The transponder key ECU matches the key's ID
    code with the vehicle's ID code, which was previously
    registered in the transponder key ECU. If the ID codes
    match, the transponder key ECU turns OFF the security
    indicator. Then when the ignition key cylinder is turned,
    the code match results are sent through the transponder
    key ECU to the ECM. After the identification results show
    that the key's ID code matches the vehicle's ID code and
    the transponder key ECU has confirmed their match, the
    immobiliser system is canceled and the engine starting
    controls (fuel injection control and ignition control) enter
    standby mode"
    So am I correct to say that all 4 (key, amplifier, ECU, ECM) all have to be programmed together? What I am experiencing is the ECU says "yes" but the ECM is saying "no"?
