Need help with identifying/replacing something
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman76, Aug 22, 2016.
  1. Aug 22, 2016 at 1:50 PM
    Sandman76
    Sandman76 [OP] Roll Tide
    Chad
    Wylie, TX
    2014 MGM Tacoma V6
    Can anybody help me identify what this is, or is used for?
    I assume its weather stripping maybe for the previous owner's camper or something. I need to put something in its place because there will be tons of residue. One end started peeling up and it looks like the guy used gorilla glue. The other thing is, the foam strip is flush on the side i took the pic of but lacks about 1 in being all the making it all the way to the other side.
    If its just weather stripping, I could probably just buy more and rip off whats there and replace. Any ideas???
  2. Aug 22, 2016 at 1:51 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Not one. Give us picture and some suggestions will be offered.
  3. Aug 22, 2016 at 1:54 PM
    DrFunker
    DrFunker Well-Known Member
    koditten likes this.
  4. Aug 22, 2016 at 1:59 PM
    Sandman76
    Chad
    Wylie, TX
    2014 MGM Tacoma V6
    Sorry about that. I was using a hosting site from my work PC...and something got blocked along the way. Hopefully you all can see it now.
  5. Aug 22, 2016 at 2:20 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    You're talking about the foam on top of the front bed wall, right? Yeah, the previous owner probably had a camper shell or something on there. The way Toyota built the 2nd generation beds the front wall is a little lower than the rails on the sides. So depending on the manufacturer of the shell and how their molds and lay-up work the bottom may be flat and would leave a gap in the front, thus foam to seal it.
    If you want to remove it you can. I have good luck with Goo Gone to remove adhesive residue.
  6. Aug 22, 2016 at 2:25 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
