Need Help With Lift Options ASAP
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lee_533, Oct 9, 2016.
  1. Oct 9, 2016 at 7:53 PM
    Lee_533
    Lee_533 [OP] Well-Known Member
    Andrew
    2016 Tacoma SR5 4X4
    2.5" Extended Travel King Coilovers, Camburg Uniball UCAs, Total Chaos LCAs, Dakar Leafs, Fox Rear Shocks, warn winch, Full Relentless armor, arb on board air compressor, 35” Tires
    Hey everyone. I have a 2016 Tacoma (first Toyota) I am looking at lifting it. I need peoples opinions on what kit I should pick. I want decent travel, nice ride on the road, and decent performance. I don't want some Rough Country crap lift, nothing against their quality, I just know they ride like garbage. I am debating the icon lift but I don't know all the stuff I need. Do I need to buy a new adjustable lower control arm? Or are the stock ones adjustable?
    My goal is to fit 285/70R17 BFGs with no to little trimming. Any help would be great since I am looking at ordering my lift this week.
  2. Oct 9, 2016 at 7:58 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    CO_0321er likes this.
  3. Oct 9, 2016 at 8:01 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Research the proper size wheels so you dont have to chop anything even with a lift with that tire size. Icon is good ... Contact Marie at Headstrong she will get you what you need for suspension ... the wheels are key for chop free.
  4. Oct 9, 2016 at 8:01 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  5. Oct 9, 2016 at 8:02 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Thanks for the link. And as far as wheel size I plan on going with aftermarket wheels to push the tires out more.
    bobrown14 likes this.
  6. Oct 9, 2016 at 8:16 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    So do I need to get an aftermarket UCA? I need some way to re-align it correct?
  7. Oct 9, 2016 at 8:20 PM
    CarsonTaco#16
    CarsonTaco#16 Well-Known Member
    Alex
    Colorado Springs, Co
    2016 TRD Offroad
    Stage 7 Icon coilovers lift, toytec front diff drop, toytec/icon u-bolt flip kit, icon rear hydraulic bump stops, spidertrax wheel spacers, 285/70/17 Nitto Ridge Grapplers, Method NV Race Wheels, Morimoto Elite Hids, Morimoto Led fog lights, rocky road outfitters super sliders, Gobi stealth roof rack.
    If you want to run a icon set up with 285s your going to have to trim. Only way you won't is cranking up on the coils which is not recommended by Icon. The max recommended exposed thread for icon is 2.13" of thread. You will have to do the cmc and trim some of the fender well, only saying this because I run icons stage 7 kit with 285/75/17s and had to trim what I just explained
  8. Oct 9, 2016 at 8:22 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Ok...how much did you have to trim...this is not a pavement pounder so it will be bashed off road. I'm trying to get an idea of what I need to do.
  9. Oct 9, 2016 at 8:25 PM
    CarsonTaco#16
    Alex
    2016 TRD Offroad
    The plastic fender well facing the back of the front tires for me is pretty much gone. Trimmed all plastic that rubbed after testing it on trails till I heard no more popping of plastic or tire wear on fender well. For the cmc just take it to an Offroad shop and they will chop a good chunk of metal off and weld a new plate that does not get in the way of the tire.
  10. Oct 9, 2016 at 8:26 PM
    CarsonTaco#16
    Alex
    2016 TRD Offroad
    I trimmed more than I probably had to, but didn't want to have to worry about doing it another time
  11. Oct 9, 2016 at 8:28 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Would you happen to have a picture? I can cut and weld everything myself. I just don't want to install the lift and tires just to have it smash something and messing something up
  12. Oct 9, 2016 at 8:29 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    what offset would you recommend?
    i was thinking
    +0mm
  13. Oct 9, 2016 at 8:30 PM
    CarsonTaco#16
    Alex
    2016 TRD Offroad
    I don't have a picture on me right now, but tommorow I will post one on here for you
  14. Oct 9, 2016 at 8:31 PM
    Joe23
    what rims are you running?
  15. Oct 9, 2016 at 8:31 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Thanks man. I was about to buy the BDS 4" kit but I read some pretty bad reviews about them
  16. Oct 9, 2016 at 8:32 PM
    Joe23
    going more than 3" isnt recommended
  17. Oct 9, 2016 at 8:37 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    That's what I was thinking unless you replace the arms and drop everything lower. I plan on going full long travel after the warranty is up, but I just want something decent for the next 5 years haha
  18. Oct 9, 2016 at 8:38 PM
    Joe23
    over 2" you need UCA.
    why wait just go LT now.
  19. Oct 9, 2016 at 8:42 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    Because it would fully void my warranty haha. I want to semi keep my warranty in stock. So the UCA's are adjustable up to 2 inches then?
  20. Oct 9, 2016 at 8:48 PM
    Joe23
    from what most have reported, you can get a 2inch lift into alignment specs with factory UCAs
    anything higher you need new UCAs.
    not sure if LT will void your full warranty. Likely just your suspension.
    Who knows depending on the dealer they'll say any mods void.
