Need help with locating an underbody insert plug part or bolt to seal side step mounting holes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UBYBC, Jan 6, 2016.
  1. Jan 6, 2016 at 9:40 AM
    UBYBC
    UBYBC [OP] Well-Known Member
    2014 Tacoma TRD OR
    Sorry for the silly question, but I sold my OEM side step bars and forgot to measure the mounting bolts. Now the holes are exposed. I
    looked at another Tacoma on the street and saw there was some plastic inserts with a groove for a flat head screwdriver in place. I have contacted three dealer parts departments and none of them can seem to locate a part number. Before I go buy a bunch of guess work screw-in inserts or push in plugs can anyone help send some light on a part number or share an example of what they are using to fill these holes. I want to keep the moisture/dirt out. Thanks for helping.
  2. Jan 7, 2016 at 1:00 PM
    jim532
    jim532 .
    SoCal - 818
    2014 Prerunner V6 double cab
    I'm about to remove some side steps too, I'd also like to know.
  3. Jan 7, 2016 at 1:13 PM
    Kysport
    Kysport Well-Known Member
    Louisville, Kentucky
    2020 Silver Sky Metallic Limited
    I've bought various size plugs at Lowes in the hardware isle. They have lots of drawers full of small hardware items nobody sees unless you pull the drawer out. Good luck.
  4. Jan 7, 2016 at 1:49 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  5. Jan 9, 2016 at 7:16 PM
    UBYBC
    2014 Tacoma TRD OR
    thanks sig45, i'll give these a try.
  6. Jan 10, 2016 at 1:04 AM
    tb3625
    tb3625 Well-Known Member
    Tyler
    Ohio
    2013 Tacoma access sport
    Thread pitch is M8x1.25. I just bought the bolts for mine about a month ago
    UBYBC[OP] likes this.
  7. Jan 10, 2016 at 7:20 AM
    UBYBC
    2014 Tacoma TRD OR
    TB, So you used metal bolts vs plastic inserts? Thanks for contributing the info!
  8. Jan 10, 2016 at 7:33 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Wrap the bolts with a little Teflon tape to keep out moisture/rust.
    UBYBC[QUOTED][OP] likes this.
  9. Jan 10, 2016 at 8:49 AM
    UBYBC
    2014 Tacoma TRD OR
    Good tip! I'll ordered some the plastic inserts for $10. But now I'm thinking the bolt Teflon method is a much better solution. Thanks again! You da man!
  10. Jan 12, 2016 at 11:10 AM
    tb3625
    Tyler
    Ohio
    Yep, I just bought grade 8 bolts and put a little bit of anti seize on them
  11. Jan 18, 2016 at 10:22 AM
    UBYBC
    2014 Tacoma TRD OR
    Thanks again fellas, got the bolt holes all sealed up!
  12. Jul 19, 2018 at 10:22 AM
    rhallmcp
    rhallmcp Well-Known Member
    Upstate NY
    2018 Trd Pro
    thanks! sold the silly running board/steps from my 18 pro and wanted to fill the holes as well. dealer wanted $34 for the plastic plugs
  13. Sep 7, 2019 at 5:27 PM
    S550ilver
    S550ilver Well-Known Member
    Bartlett, TN
    2019 Tacoma Double Cab TRD Off-Road
    ICON Stage 5 Lift, 18x9 Fuel Shok, Nitto Ridge Grappler 285/65/18 tires
    Will These work on a 3rd gen too? Removed my Predator side steps on mine and wanna put something back in the holes.
  14. Sep 7, 2019 at 5:44 PM
    Sig45
    Mark
    Maine
    I don't know.
  15. Sep 8, 2019 at 4:35 PM
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    That’s why when I sold my side-steps I kept the bolts.
