Need help with lower stock bushings for 5100 Bilsteins (front)
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Driver, May 18, 2016.
  1. May 18, 2016 at 12:34 PM
    The Driver
    The Driver [OP] Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Hi all:
    I replaced the rear factory leafs with Alcan Leafs (review coming soon) and OME greasable shackles. The front received a rebuilt rack from the "Rack Doctor) and new tie rods.
    The problem: I need to raise the front as even though I asked for no lift leafs, the have lifted the rear a good 2.5 inches.
    The front shocks, which were installed 4 years ago, have gotten a lot snow due to be daily driven during snow weather and skiing. As such on of the shock bolts needs to be cut off to be removed from the coilover (spring).
    Downsouth Motors (where I originally bought the shocks) says that the bushings are vulcanized unto the shock, and that as such I'll need to replace the shocks. Downsouth website shows Toyota part # 90948-01056 and 90948-01057 as bushings needed to be installed with the 5100 series.
    Can anyone shed any light as to what I need?
  2. May 18, 2016 at 12:38 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  3. May 18, 2016 at 2:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I would trust what DSM is telling you to be correct. I really doubt you can just replace that billie shock bushing.
  4. May 18, 2016 at 2:50 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had to buy a front shock replacement bushing / washer kit for $20.99 when I bought my front adjustable 5100's from ToyTec.com
  5. May 18, 2016 at 2:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You're referring to the top bushing right?
    OP, I was referring to the bottom bolt and bushing.
  6. May 18, 2016 at 5:10 PM
    The Driver
    Raph
    Problem is, verbally they say I need new shocks, while their site shows a part number for bushings. So which way I'm supposed to go?
    Roger that.
  7. May 18, 2016 at 7:41 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    My bushing/washer kit was fit was for the bottom of the shock
  8. May 18, 2016 at 8:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Make certain from DSM that they will fit the lower mount on your RCD 5100s. They may not.
    The shock we (TW) refer to as 5100s is a shock made by bilstien for a company call Race Car Dynamics. These shocks are spec'd by RCD, and Bilstien builds them. Bilstien does not sell these, only RCD does. In fact, Bilstien does not sell a comparable, adjustable front shock for Tacomas.
    One of the RCD specs is a bottom bushing that is bonded to its mount.
    Yes, there are bushings available for Bilstien shocks. Several different sizes in fact to fit other applications, The rear Tacoma posts for example. The bushing you see listed on DSM site are for Bilstien shocks. For their 5125 series shocks for sure and maybe others.
  9. May 19, 2016 at 1:09 PM
    The Driver
    Raph
    Thanks. Your post explains a lot!
