Need help with my 2015 tacoma transmission drain and fill !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tenntaco4x4, Sep 3, 2023.
  1. Sep 3, 2023 at 10:22 AM
    tenntaco4x4
    tenntaco4x4 [OP] New Member
    I have followed all the post on the drain and fill it didnot seem that bad since I have been chaining my own oil for years. here is my problem, I measured the amount of trans oil I took out about 3.4 qts. replace it with 1/2 qt more, did the OBD jumper and waited for the AT temp light to stay on, (better half helped) when it came on, open the check plug, no fluid came out ? Shut it down and added 1/2 more fluid, next day did the same ATF temp check again no fluid out of the check port so now it 4qts total that has been add and still no trickle of fluid, So what should I do next add a 5th qt? that sounds like a lot.. I should add I bought the Tacoma used with 46000 miles on it and it appear that it has never been touch on the Transmission, So what have I done wrong and what should I do now??? Thanks for all the help ...
  2. Sep 3, 2023 at 10:44 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    welcome to TW
    turck is on level ground, just checking
    check the radiator for ATF leaking in and mixing or any other leaks?
    radiator replaced at some point and ATF was not added to replace what was in the radiator maybe
    there are some reports of underfill from the factory but not this much
  3. Sep 3, 2023 at 11:03 AM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Add another quart. Start up, open the check plug. It doesn't have to be up to temp yet. First step is to get it overfilled. If it comes out of the check plug cold, you know you are overfilled.
    Then do the temperature process as a final step.
  4. Sep 3, 2023 at 11:05 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  5. Sep 3, 2023 at 1:06 PM
    tenntaco4x4
    Thank you I will try this I did Crack the plug and some came out but engine was not runnin sounds like a plan I have to ge my baby running tomorrow thanks again it's a 2015 gray extended cab trd pro gray
  6. Sep 3, 2023 at 1:15 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    You have to have the truck running to check the level. It's also not good to have too much oil and drive it around.
  7. Sep 4, 2023 at 10:17 AM
    tenntaco4x4
    I wish to thank all that posted a reply on my problem with transmission fluid, A special thanks to 2WD hit the nail on the head, It was low from the factory about 1qt and 3/4s, filled it with a extra and did what
    ran the engine and checked the level had it come out, closed and waited until it cooled down and did the OBD jumper until temp light came on and opened and removed excess until trickle, So had a scary moment
    until all helped arrived Thank you all so much.. will post pic of my ride later.... Glad to have it back...
    Doc Samson, road2cycle and Dm93 like this.
