need help with my amp install
Discussion in 'Audio & Video' started by krisjw101, Apr 22, 2012.
  1. Apr 22, 2012 at 8:50 PM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    Hi guys,
    I decided to put in my kenwood speakers and amp today got them all wired, reconnect my ground to the battery, turn the truck on and the amp doesn't turn on. I have no idea why!!!! I grounded it to the bolt on the drivers side (under the plastic molding there is a bolt that goes into the floor that a bunch of wires to already). I rechecked the power control wire and the power wire and everything looked good. why isnt it even turning on?
  2. Apr 22, 2012 at 8:56 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    do you have the remote wire hooked up?
  3. Apr 22, 2012 at 8:59 PM
    swalik
    swalik A waffle is like a pancake with a syrup trap.
    Sean
    Grass Valley, CA
    94 4Runner
    kenwood deck, two 12" kenwood subs, power acoustik 2000watt amp, gabriel air shocks, cobra cb radio, 25 watt radioshack pa speaker, magnaflow exhaust
    Do you have a multi-meter? If so, check to make sure power and ground are good. Has the amp been used before?
  4. Apr 22, 2012 at 9:30 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    I' sure i hooked up the right remote wire but I will look. Im not sure how to use a multimeter?
  5. Apr 22, 2012 at 9:32 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I would check the amp power wire fuse and any fuses on the amp itself to see if they are blown. Swap in another good working fuse to test even if the fuses look good.
  6. Apr 22, 2012 at 9:35 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    how would I know what was wrong if i test with a multimeter? If i get a reading the amp is broken and if I dont my wiring is wrong somehow?
  7. Apr 22, 2012 at 9:37 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    I will try swapping the fuses as well
  8. Apr 22, 2012 at 9:38 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    speaking of fuses, why is there a fuse on the power wire as well as the amp?
  9. Apr 22, 2012 at 9:40 PM
    swalik
    Sean
    Grass Valley, CA
    94 4Runner
    Use the multimeter to make sure there is 12 volts between the battery and the power on the amp. Then you will at least know if power is getting to the amp.
  10. Apr 22, 2012 at 9:43 PM
    kmok
    Kyle
    Columbus, Ohio
    Extra protection or maybe easier access? I've blown the fuse on the amp power wire to my amp a few times myself lol
  11. Apr 22, 2012 at 9:43 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    ok ill check. what do i do if I dont get a reading?
  12. Apr 22, 2012 at 9:47 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    check remote turn on first. on most kenwoods, that little red triangle on the top thats like an emblem, is lit by the remote turn on. so if that isnt coming on, that means its your remote turn on wire for sure. what kind of head unit? if u tell me model i might know what color your remote turn on wire should be. but like i said, that red triangle is powered only by the rto so if that thing isnt connected fully, or just straight up isnt connected to the right wire, then you really have an easy fix. oh and theres fuses on both for several reasons, mainly just for double protection, protection for your amp as well your truck. if something craps out on your battery or shorts or something weird, that power wire is cut off before it gets too far, provided you put that inline semi close. the other fuses are mainly to protect the amp, you really dont ever have to worry about popping fuses in the amp as long as its a decent amp and your not trying to force its max power through, which you never should come close because it will start distorting,
  13. Apr 22, 2012 at 9:51 PM
    cosgrc
    cosgrc Well-Known Member
    Madison, AL
    2012 MGM DCSB TRD Sport 4x4
    OME Lift, 887, Dakars
    Do you have an aftermarket stereo? If so, did you hook it to the blue wire or the blue/white wire coming from the radio? If it works on the radio but not on a CD, that could be the problem. Solid blue wire is power antenna (thus it goes off when the CD is on). If it's not this, check what everybody else says - should have 12 volts on the positive terminal and remote turn-on (when the system is on) on the amp. Is the power light on, on the amp?
  14. Apr 22, 2012 at 9:51 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Its a kenwood kdx-395 i believe.
  15. Apr 22, 2012 at 9:52 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    I will pull out the HU tomorrow and look to make sure its all good
  16. Apr 22, 2012 at 9:53 PM
    cosgrc
    Madison, AL
    I must have been typing while you hit submit. :)
  17. Apr 22, 2012 at 9:55 PM
    swalik
    Sean
    Grass Valley, CA
    94 4Runner
    With the truck on, if there is no power getting to the amp, you most likely have an issue with your power cable's inline fuse, or like others have said your remote turn on wire is not connected properly.
  18. Apr 22, 2012 at 9:56 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    no the red kenwood triangle doesnt light up at all. so its the remote wire for sure then
  19. Apr 22, 2012 at 9:58 PM
    swalik
    Sean
    Grass Valley, CA
    94 4Runner
    What did you tap the remote wire into?
  20. Apr 22, 2012 at 9:58 PM
    onesixseven
    Tyler
    02 Prerunner SR5
    :p yea well wudev it works. yea cuz experience tells me, at least with any of my alpines/jvc/kenwoods/etc... that solid blue is rto, but when i was throwing is a sony for a buddy, i was stumped. couldnt figure it out. checked all my grounds a million times, fuses, even tried returning the amp, eventually found out sony uses the blue/white for rto. i was like :confused: but live and learn i guess :rolleyes:
