Need help with my electrical gremlins
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oldyoungman, Aug 2, 2022.
  1. Aug 2, 2022 at 1:10 PM
    Oldyoungman
    Oldyoungman [OP] Member
    Thomas
    1997 White Tacoma 4WD Extra cab
    I've got some odd things going on with my electrical system. After leaving my truck unused for a few months large accessories will now kill the engine. Accessories such as turn signals, DRLs, break lights, dome light, window wipers, and even ignition will drop the voltage and dim the lights. Larger appliances like the headlights and blower will outright kill the engine if I turn them on.
    I am really at a loss. What could be happening here?
    All the fuses are good and the battery and terminals are brand new.
  2. Aug 2, 2022 at 1:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like your alternator failed or you have a very corroded ground wire somewhere
    MalinoisDad likes this.
  3. Aug 2, 2022 at 1:15 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    She can't handle the load. That was reason enough to end my first marriage, and reason enough for you to do some looking for the cause of this issue.
    Rodents could have chewed on stuff and you could have a ground wire hanging on for dear life somewhere by a few strands of wire. Since you said a few months of no use...
    Plain Jane Taco likes this.
  4. Aug 2, 2022 at 1:33 PM
    Oldyoungman
    Thomas
    UPDATE: Just put in a volt meter to my cigarette lighter and watched the volts while driving. It was reading 12.0 and 11.8 but occasionally would read 13.5 and 14 and that's when I had no problem with the headlights killing the engine. After a minute of headlights and good volts the engine would die and have low voltage again.
  5. Aug 2, 2022 at 1:35 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Could be a loose wire, I’d check the one on the back of the alternator.
    Or maybe the regulator is failing in a most irregular fashion
  6. Aug 2, 2022 at 1:35 PM
    Oldyoungman
    Thomas
    It could be the alternator even though its relatively new and I've been searching for a bad grounding wire for a while.
    I really like your tacoma's front bumper, where did you get it?
  7. Aug 2, 2022 at 1:41 PM
    Speedytech7
    Thanks! It is from the 4x4 Store in Clarkston, WA
    http://the4x4store.com/bumpers
  8. Aug 2, 2022 at 1:42 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Check for rodent damage
  9. Aug 2, 2022 at 1:42 PM
    MalinoisDad
    Michael
    If you don't find any obvious bad wires it's free to have your battery load tested at most parts stores. Maybe you left something on and draining your battery before it sat for a few months and you now have a bad cell or two inside the battery. It's possible.
  10. Aug 2, 2022 at 1:43 PM
    MalinoisDad
    Michael
    I heckin' said that earlier! haha
    But screw it, we'll hammer it home.
    04Pre_Runner likes this.
  11. Aug 2, 2022 at 1:46 PM
    Plain Jane Taco
    USA
    Yeah.....saw that after I posted it. But rodent damage seems to always be the last thing people think of. But the second I hear something like, "haven't driven my truck in weeks", it's the 1st thing I think of.
  12. Aug 2, 2022 at 1:50 PM
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    How do your belts look? Could it be skipping?
  13. Aug 2, 2022 at 1:50 PM
    MalinoisDad
    Michael
    Same here. Luckily and knock on wood, I have not had it happen to a vehicle of mine but I see them ruin hot tubs all the time. Relentless little shits.
  14. Aug 2, 2022 at 1:56 PM
    Plain Jane Taco
    USA
    Squirrels laid waste to my buddy's '16 4Runner and mice to another friend's Mitsubishi 3000GT several years ago.
  15. Aug 2, 2022 at 1:57 PM
    Speedytech7
    it was probably for the best
  16. Aug 2, 2022 at 1:57 PM
    Plain Jane Taco
    USA
    Not when it was a VR-4. :(
    Speedytech7[QUOTED] likes this.
