need help with my Sequoia.
Discussion in 'New Members' started by meat evo, Aug 19, 2011.
  1. Aug 19, 2011 at 4:35 AM
    meat evo
    meat evo [OP] Member
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    Hello all, I'm a long time forum user of many vehicle specific communitys, just new to this one.
    I did some searching on Google on some other issues, and a lot of things pointed to this site, hope you guys can help.
    I just bought a 2003 Sequoia Limited for 10k with 100k miles. its aiight.
    First, when i hit a mild bump i hear a deathly rattle, but when I get under the truck, And shake everything I can, I cant find out what its from.
    The rear window would not roll down, do I replaced the motor. Works great now.
    all of a sudden, the rear hatch would not lock. I can put the kit in the rear hatch key hole, and it will still lock and unlock the other 4 doors, but not the hatch. Nothing was unplugged or removed when I replaced the window motor. I have double checked everything visually.
    Any input on these 2 things would be great, Thanks!
  2. Aug 19, 2011 at 4:42 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Welcome, sorry though, I'm no help for you.
  3. Aug 19, 2011 at 4:50 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I'm not sure how much we can help you here, but we will give it a good shot. You would be the first Sequoia on the forum to my knowledge.
    For the bump rattle, I would look at any and all exhaust shrouds. Make sure all of the exhaust hangers are good. Also check for stones or debris in the shrouds. Check the transmission mounts too. Where does the sound originate from?
    You can try greasing the hatch lock. Or the actuator may need replaced.
    Welcome to TW
  4. Aug 19, 2011 at 5:03 AM
    Namyo
    Namyo -
    Wud up Chesapeake? Smokey ova there huh :mad:
    Maybe latch not working and rattle is same chit :notsure:
  5. Aug 19, 2011 at 5:48 AM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    its not exhaust for the rattle, and in wondering how the rest of the doors lock and unlock except the hatch when it seems like its the power mechanism. but i dunno. ill have to dig into it a little deeper.
    The rattle seems like mid/rear and it sounds horrid when I dont try to keep it quite. Ill check the drive shaft and transmission mounts, since they are both in that area.
  6. Aug 19, 2011 at 5:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    How does the suspension look? I'm not sure if you have leafs or coils in the rear of that thing.
  7. Aug 19, 2011 at 6:11 AM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    pretty positive its coils/shocks. The suspension looks new. I went to toyota and they said some suspension work was done prioe to me picking it up. I got it some a random used car dealer though, so its not like I can take it anywhere to get it fixed for free. Im gonna try to stop by my buddys shop today and have him check it out.
    also, on the drive shaft, do they adjust when you go into 4 wheel? i can see where mine has slid back and forth and there is a nice greese line/splatter on the bottom of the truck, looks fairly new.
  8. Aug 19, 2011 at 6:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No. The slip yoke slides in and out of the shaft as the rear suspension travels up and down. Sounds like the greased it up already before you picked it up.
  9. Aug 19, 2011 at 6:48 AM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    ok cool, that's good to know.
  10. Aug 19, 2011 at 6:07 PM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    the horrid rattle was an old brake pad that wasn't removed, instead, it was allowed to fall and i guess they didnt look for it.
  11. Aug 19, 2011 at 6:13 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Glad you found your rattle. It sounds like your other problem is definitely the door lock actuator. Hopefully it is separate from the latch otherwise it will be $$$. Good luck. And welcome to the forum!!!
  12. Aug 20, 2011 at 5:18 AM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    yea, when I was looking, it looks like the door lock actuator is not even there!
  13. Aug 20, 2011 at 5:55 AM
    meat evo
    Justin
    Chesapeake
    03 Sequoia Limited
    k&n
    Does anyone know what my Sequoia would compare to? Possibly a Tundra as far as the frame? Im looking at getting a new set of headers and running a new exhaust and I think the Tundra came with the same 4.7 and I think the headers for the Tundra will fit my application. anyone know what I can search to find out more information?
