need help with new lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DERG783, Nov 12, 2013.
  1. Nov 12, 2013 at 4:58 PM
    DERG783
    DERG783 [OP] Member
    doug
    maryland
    3" rough country lift, 1.25" wheel spacers, smittybilt roof rack, 4 kc lights in front, 2 kc light in rear, ax and shovel mount
    i have a rough country 3" lift which was nice until my 32" tires wore down and i decided to go to 33" goodyear dura tracks. (which do awesome offroad) but when i put them on the tires rubbed on my upper control arm so i got 1.25" spacers ignoring that they're terrible for my wheel bearings. almost a year later just had to replace my wheel bearings, so i want to get a different lift to eliminate the spacers any suggestions?
    also im a 19 yrs old and in college so money is kinda scarce for me, please help
  2. Nov 12, 2013 at 5:02 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    new UCA's?
    Ryans4×4 likes this.
  3. Nov 12, 2013 at 5:09 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You need new wheels with different offset to push the tires out and away from ucas...
  4. Nov 12, 2013 at 5:11 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Best lift for you since your on a budget would probably be get some Bilstein 5100s for the front and set them to 2.5 and maybe throw in an aal in the rear. Check out Toytec lifts. They have everything from just shocks to complete icon lifts and all kinds of goodies. down south motorsports has some good deals too. New wheels might be a good idea too.
  5. Nov 12, 2013 at 5:13 PM
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    Thinner wheel spacers like .75 or 1"
    Bora comes to mind
  6. Nov 12, 2013 at 5:16 PM
    reece13
    North Carolina
    I have bora .75 spacers on my truck and havn't had any issues with bearings...but i only have 42k on my truck. Bad thing with spacers under 1.25 is you have to replace or "modify" existing wheel studs.
  7. Nov 12, 2013 at 5:18 PM
    DERG783
    DERG783 [OP] Member
    doug
    maryland
  8. Nov 12, 2013 at 5:19 PM
    DERG783
    DERG783 [OP] Member
    doug
    maryland
    i have 136000 miles and do a good bit of offroading and what ive heard is that spacers are never good so im trying to just get rid of them
  9. Nov 12, 2013 at 5:36 PM
    BulletToothTony
  10. Nov 12, 2013 at 7:41 PM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    agreed, you already have about 500 into the original lift and spacers, so dumping another 500 into another partial kit seems like a bad idea. save up and go for a complete kit with no spacers and a good offset wheel
  11. Nov 12, 2013 at 8:02 PM
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    i have a pair of brand new eibach coils and front bushing set i'll sell ya for 180 shipped
  12. Nov 13, 2013 at 7:09 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    Depends on the offset, a 4.5 bs should be alot better for the wheelbearings than a 1.25 spacer, although i use to blow out wheelbearings on my ranger with the 10" wide rims .. but that is a whole other story.
  13. Nov 13, 2013 at 7:13 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    a question not asked is how many miles did you get out of the original bearings? I still say if you got a decent life out of the original bearings, then hold off pulling the trigger do alot of research for what you need and build it up slowly, you"ll get a great result and have exactly what you want.
  14. Dec 12, 2013 at 8:21 AM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    A different lift isn't going to help with tire clearance/rubbing. You need wheel spacers or new wheel with different backspacing/offset. The lift will not help with bigger tires.
  15. Dec 12, 2013 at 9:34 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this ^^
    also, OP, dont go with the procomp lift..
    It DOESNT have blocks, just an AAL, but it still is garbage. ask me how i know.
    the coils sagged, the bushings in the shocks lower eyelet blew out, the AAL is stiff as hell.
    save your money if you wanna go with a different lift, but, as far as your rubbing.. new wheels with the correct BS is what you need.
