need help with new rims
Discussion in 'Wheels & Tires' started by Jblake0212, Jul 18, 2018.
  1. Jul 18, 2018 at 9:34 AM
    Jblake0212
    Jblake0212 [OP] New Member
    Jon
    2012 tacoma 4x4 regular cab
    My son has a 2012 regualr cab 4x4 tacoma. i just put new tires on it, 26/70/16. he wants new rims for his birthday. the problem i am having is that im not sure what offset to get. i called one of the wheel stores and they said that the stock steel wheels are a +30 offset and advised me to go with a +15 or +20. i have looked online and it says that the stock steel wheels are -17 offset. we are wanting to stick out of the fenders slighty to give it a wider stance but not to far. any adive or pictures maybe so i know what to get?? thanks
  2. Jul 18, 2018 at 12:30 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    You need 16x8 rims with +0 offset and 4.5" back spacing. Many rims come in that configuration. Try to also stay with rims that have a 106mm (106.2 usually) center bore.
    Bagman and eccracer104 like this.
  3. Jul 18, 2018 at 12:38 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    ^^^ Yep, 0 offset, 4.5" BS should do the trick
  4. Jul 19, 2018 at 10:39 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    ^^ Agreed. 16x8 0mm offset, 4.5" back spacing and a hub bore between 106-108 will do the trick :thumbsup:
    BassAckwards[QUOTED] likes this.
  5. Jul 24, 2018 at 6:59 AM
    Deadsquiggles
    Deadsquiggles Well-Known Member
    VA
    2019 Tacoma SR V6 Double Cab 4WD Barcelona Red
    None
    If the hub bore is 108, do you need the hub ring to reduce it two millimeters? Asking since I plan on putting wheels on my '17 that have a hub bore of 108.
    eccracer104 likes this.
  6. Jul 25, 2018 at 12:42 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Some say yes, some say no.
    My last truck I ran wheels with a center bore of 108, no hub centering rings, and never had an issue.
    They're cheap insurance though, I'd recommend getting them just in case.
    I sell them for $11.95 as a 4 pack.
  7. Jul 25, 2018 at 12:46 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Do you have a Discount Tire store in your area? If so, head there. Good choice of wheels and they know what you need.
